Acech
Using a USB keyboard as a controller
Thu Jan 31, 2019 8:24 am
Good morning all,
I have a raspberry pi controlling RF sockets in order to turn specific lights on and off etc. I also have a USB keyboard which I would like to use as the interface, so as you press a specific key a script gets run turning on different light configurations.
I am struggling to find any links to how this might have been done before. I guess there are two things that need to happen - firstly the keyboard needs to be disabled - it is connected to a headless setup, so I wouldn't want the keyboard typing in the login box that would be open on the pi.
Secondly I would need some way to buffer the keyboard and throw an interupt when a key is pressed.
Are these things possible? And if so could anyone offer any advice as to how to do it?
Many thanks,
Chris
mattmiller
Re: Using a USB keyboard as a controller
Thu Jan 31, 2019 9:00 am
Have I got this right?
You want your program to receive different signals when different key are pressed on your keyboard but you don't want the keyboard to work as a normal keyboard?
Acech
Thu Jan 31, 2019 10:24 am
Yes! - Sorry for being ambiguious!
I want to be able to use the keyboard on a headless set up, so as the pi boots it starts waiting for key presses. If a key is pressed a script will run.
tvjon
Thu Jan 31, 2019 11:27 am
...Are these things possible?...
Many thanks,
Chris
Yes.
Some of my RPi applications use up almost all of the GPIO's switched to an alternative dedicated function, so I sometimes have to use a different method of input, the simplest (& cheapest) being to use a USB (or even PS/2, as they are often better quality) keyboard. You can even have outputs as well for feedback, in the form of a rudimentary code via the typical 3 keyboard leds.
One such application is to practice playing simple tunes using midi but via a qwerty (azerty etc.) dedicated keyboard. Obviously there's no velocity possible, just note on & off, but it's fine for when impractical to carry a bulky midi controller.
You'd still have to decode the on/off midi sequences & decide if such is feasible for your particular devices.
I always do this whilst having monitor(s) & keyboard connected to the RPi, but headless shouldn't be a problem.
Are you familiar with building applications from source code?
"Secondly I would need some way to buffer the keyboard and throw an interupt when a key is pressed."
I didn't think your post ambiguous, but can you elaborate on your thinking there, bearing in mind you haven't given any details of the rf devices?
topguy
Thu Jan 31, 2019 12:20 pm
I would suggest alternative solution: ( much easier to implement IMO compared to what you suggest)
- Autologin that automatically runs a script that listens for keypresses and runs the commands you want.
A special keypress exits that script and gives you normal shell.
