Tamu UOB
raspi taking photo on boot every day at 10past and 50past
Tue Sep 11, 2018 9:24 am
Hi I'm trying to make a code to get a raspi to take a photo on boot at 10 past the hour and 50 past the hour, I have tried a cron tab generator which will take a photo but won't be sequential and I can't get it to do it from boot, I'm a compleat novice at coding so any help would be greatly appreciated.
pcmanbob
Re: raspi taking photo on boot every day at 10past and 50past
Tue Sep 11, 2018 10:00 am
Hi.
Assuming you have some code to take one picture when commanded, getting cron to call the program is simple.
I am however a little confused as you say you want to to take it on boot at 10 & 50 min past the hour ?
on boot would suggest you want it to just take your picture when the pi boots, were as you say you want it to take them twice and hour at 10 & 50 mins, which would suggest you want to take multiple pictures.
So first lets assume your picture taking program is located in" /home/pi " and is called " takepic.py "
so to take a picture at boot
@reboot python /home/pi/takepic.py
now because cron runs very early in the boot process hardware may not be ready so you may have to add a short delay to allow the pi to finish booting before taking your picture like this
@reboot sleep 20 && python  /home/pi/takepic.py
Now to take pictures at 10min past the hour
10 * * * *  python /home/pi/takepic.py
if you want it to run only during certain hours then you would do it like this ( 8 am to 8pm )
10 8-20 * * *  python /home/pi/takepic.py
and 50min past the hour will be similar
50 * * * *  python /home/pi/takepic.py
50 8-20 * * *  python /home/pi/takepic.py
of course the pictures taken at 10 & 50 min past the hours will only work correctly if the time is correctly set on your pi and they will not be taken at boot only at the allotted time.
Tamu UOB
Tue Sep 11, 2018 10:49 am
Hi sorry yes I want the script to run all day automatically once the pi has booted up. eg take a picture at 7:10 then 7:50. does cron run automatically or do I need a bit of extra code?
and I'm guessing it will be two bits of code one for the 10 past and a separate one for 50 past?
RaTTuS
Contact: Twitter YouTube
Tue Sep 11, 2018 11:14 am
crontab -e
10,50 * * * *  /path/to/correct/python /home/pi/takepic.py
is all you need
Covfefe
pcmanbob
So you have your script that takes the picture and then exits I would hope.
So you just need cron to run this script for you at the appointed times as I explained in the examples , using 2 cron lines is easier and allows you to simply change one if you want.
but you could do it with just one line which would than start like this
10,50 * * * *
which would take a picture at 10 & 50 min past the hours 24 hours a day.
cron runs automatically on pi boot so all you need to do is add the lines to the cron file using crontab -e not forgetting to add a blank line after your entries at the end of the file.
Tamu UOB
Tue Sep 11, 2018 11:19 am
Thank you I will give that a go, i have been using the raspstill command for taking a picture
Tamu UOB
Tue Sep 11, 2018 3:18 pm
so i put in the code 50 * * * * python /home/pi/Camera.py
and get the error
bash: 50: command not found
any ideas
DirkS
Tue Sep 11, 2018 3:27 pm
and get the error
any ideas
That's the line that needs to go into the crontab.
Edit the table with
crontab -e
Then put the above that line into the file. Save and Exit and wait until it's 10 to the hour...
Tamu UOB
Tue Sep 11, 2018 3:37 pm
how do i save and exit? silly question but i cant seem to do it
DirkS
Tue Sep 11, 2018 3:47 pm
Assuming you ended up in 'nano': <Control+X>Y<ENTER>
BTW: available key codes should be at the bottom of the editor window.
Tamu UOB
Tue Sep 11, 2018 3:54 pm
Thank you i was adding ^ to the line rather than pressing control
DirkS
Tue Sep 11, 2018 3:59 pm
^ is often used as a symbol for control
pfletch101
Tue Sep 11, 2018 9:18 pm
Be aware also that cron runs with its own somewhat cut down environment. All file paths (e.g. for your saved pictures) should be specified explicitly (e.g. /home/pi/images/snap1.jpg).
Gavinmc42
Tue Sep 11, 2018 11:36 pm
You can do a sequential filename by writing the name of the image file into a file and then next time cron fires your script the script reads the fillename out of the file and increments it then writes it back.
Or if you have a network connection or RTC use a file name with the timestamp in it.
You don't need to use Python, Bash Script files can do all this too.
I'm dancing on Rainbows.
