Hellindros
Get Hyperpixel 4.0 display to work with PINN bootloader
Fri Sep 07, 2018 3:40 am
hi guys so still a bit unsure on getting the hyperpixel 4.0 to run in the pinn bootloader and could use a little help , so i need to go to the pinn recovery directory and create a script /mount that will run the hyperpixel4-init code
like
sudo nano /tmp/media/pinn_init.sh (file name pinn wants in recovery partition)
add the hyperpixel4-init code
#!/bin/bash
SERVICE_NAME=“hyperpixel4-init.service”
SERVICE_PATH="/etc/systemd/system"
BINARY_NAME=“hyperpixel4-init”
BINARY_PATH="/usr/bin"
OVERLAY_PATH="/boot/overlays"
OVERLAY_NAME=“hyperpixel4.dtbo”
CONFIG="/boot/config.txt"
CONFIG_LINES=(
“dtoverlay=hyperpixel4”
“overscan_left=0”
“overscan_right=0”
“overscan_top=0”
“overscan_bottom=0”
“framebuffer_width=800”
“framebuffer_height=480”
“enable_dpi_lcd=1”
“display_default_lcd=1”
“dpi_group=2”
“dpi_mode=87”
“dpi_output_format=0x7f216”
“display_rotate=3”
“hdmi_timings=480 0 10 16 59 800 0 15 113 15 0 0 0 60 0 32000000 6”
if [ $(id -u) -ne 0 ]; then
printf “Script must be run as root. Try ‘sudo ./install.sh’\n”
exit 1
fi
if [ -d “$SERVICE_PATH” ]; then
cp dist/$BINARY_NAME $BINARY_PATH
cp dist/$SERVICE_NAME $SERVICE_PATH
systemctl daemon-reload
systemctl enable $SERVICE_NAME
systemctl start $SERVICE_NAME
printf “Installed: $BINARY_PATH/$BINARY_NAME\n”
printf “Installed: $SERVICE_PATH/$SERVICE_NAME\n”
else
printf “Warning: cannot find $SERVICE_PATH for $SERVICE_NAME\n”
fi
if [ -d “$OVERLAY_PATH” ]; then
cp dist/$OVERLAY_NAME $OVERLAY_PATH
printf “Installed: $OVERLAY_PATH/$OVERLAY_NAME\n”
else
printf “Warning: unable to copy $OVERLAY_NAME to $OVERLAY_PATH\n”
fi
if [ -f “CONFIG" ]; then for ((i = 0; i < {#CONFIG_LINES[@]}; i++)); do
CONFIG_LINE=”${CONFIG_LINES[$i]}"
grep -e “^#$CONFIG_LINE” CONFIG > /dev/null STATUS=?
if [ $STATUS -eq 1 ]; then
grep -e “^$CONFIG_LINE” CONFIG > /dev/null STATUS=?
# Line is missing from config file
echo “$CONFIG_LINE” >> $CONFIG
printf “Config: Added $CONFIG_LINE to $CONFIG\n”
else
printf “Skipped: $CONFIG_LINE already exists in $CONFIG\n”
fi
else
sed $CONFIG -i e “s/^#$CONFIG_LINE/$CONFIG_LINE/”
printf “Config: Uncommented $CONFIG_LINE in $CONFIG\n”
fi
done
else
printf “Warning: unable to find $CONFIG, is /boot not mounted?\n”
printf “Please add $OVERLAY_CONFIG to your config.txt\n”
fi
cntrl + X to save
how do i mount this in the pinn recovery directory , love the screen trying to make more portable :)
