jal
Best way to start shell script on startup?
Fri Oct 26, 2012 8:56 am
Hi all,
What would be best way to run shell script on startup?
joan
Re: Best way to start shell script on startup?
Fri Oct 26, 2012 11:09 am
I prefer to make a reboot entry in crontab. Others prefer adding entries in /etc/init.d.
For crontab use
sudo crontab -e
to create and
sudo crontab - l
to list.
For details see
man crontab
man 5 crontab
jal
Fri Oct 26, 2012 1:11 pm
If I want to run my script once in every minute?
BlackJack
Fri Oct 26, 2012 1:16 pm
@jal: Then the answer is definitely ``crontab``.
while not self.asleep():
    sheep += 1
jal
Fri Oct 26, 2012 1:37 pm
should i add something like this:
* * * * * ./myscript.sh
tedhale
Fri Oct 26, 2012 1:43 pm
/etc/rc.local
is for misc startup stuff. But it does sound like you might want to crontab a script
- Ted B. Hale
http://raspberrypihobbyist.blogspot.com
Joe Schmoe
Fri Oct 26, 2012 1:57 pm
Note that if you really want it to run every minute, it will probably be easier to include that logic in the script itself.
I.e.,:
while :;do
# do stuff
sleep 60
done
Then you just need some way to launch it on startup and you're all set.
jal
Fri Oct 26, 2012 2:02 pm
Yes, when tested this script I used "sleep 60"
I dont't really care if this timing is done by cron or script, I just want it to work. I have added quite few different lines to crom, but nothing helps :(
Joe Schmoe
Fri Oct 26, 2012 2:06 pm
One reason why it is better to do it in the script (one of many) is that it avoids cron logfile clutter.
If you have something spawning an entry in the cron log every minute, you find yourself unable to effectively read that log file.
joan
Fri Oct 26, 2012 2:09 pm
Add the following line to yours or the root crontab. It's probably simplest to add it to root so
sudo crontab -e
Add the line
* * * * * /home/<your-directory>/<your-script>
Use
sudo crontab -l
to verify the line was added correctly.
Ensure your script is executable
chmod +x /home/<your-directory>/<your-script>
Joe Schmoe
Fri Oct 26, 2012 2:14 pm
Bad advice, as noted above.
