Ganjanouille
[SOVED] Start python on RPi Zero startup
Wed Apr 04, 2018 1:45 pm
Hi folks!
I finished my script and tried to make it launch on startup but it does'nt work.
I first tried with rc.local file and second with cronetab.
rc.local content:
#!/bin/bash
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
#Midi controller programm
python /home/pi/oled/threadingOledMidiA1.py&
touch /tmp/test.txt
echo "$(date) => It's running" > /tmp/test.txt
So the test file works just fine. Why isn't my python script?
command "cronetab -e" content:
# Edit this file to introduce tasks to be run by cron.
# Each task to run has to be defined through a single line
# indicating with different fields when the task will be run
# and what command to run for the task
# To define the time you can provide concrete values for
# minute (m), hour (h), day of month (dom), month (mon),
# and day of week (dow) or use '*' in these fields (for 'any').#
# Notice that tasks will be started based on the cron's system
# daemon's notion of time and timezones.
# Output of the crontab jobs (including errors) is sent through
# email to the user the crontab file belongs to (unless redirected).
# For example, you can run a backup of all your user accounts
# at 5 a.m every week with:
# 0 5 * * 1 tar -zcf /var/backups/home.tgz /home/
# For more information see the manual pages of crontab(5) and cron(8)
# m h  dom mon dow   command
@reboot python /home/pi/oled/threadingOledMidiA1.py
And yes I suppose there is an empty line at the end of cronetab.
uname -a output:
Linux raspberrypi 4.9.80+ #1098 Fri Mar 9 18:51:28 GMT 2018 armv6l GNU/Linux
And finally my python script:
#	This programm shows Waldorf Blofeld informations on SSD1306	#
import serial
import sys, math, time
from threading import Thread
import Adafruit_GPIO.SPI as SPI
import Adafruit_SSD1306
from PIL import Image, ImageFont, ImageDraw
#Blofeld control change mapping
blofeld_B0 = 	[
						"Bank MSB",
						"ModWheel",
						"Brth Ctrl",
						"Undef",
						"Ft Ctrl",
						"Glide rate"
blofeld_B1 = 	[
						"Dta Entry",
						"Chnl Vol",
						"Balance",
						"Undef",
						"Pan",
						"Expr.",
blofeld_B2 = 	[
						"Arp rnge",
						"Arp length",
						"Arp Active",
						"LFO1 Shape",
						"LFO1 Speed",
						"LFO1 Sync"
blofeld_B3 = 	[
						"LFO1 Delay",
						"LFO2 Shape",
						"LFO2 Speed",
						"LFO2 Sync",
						"LFO2 Delay",
						"LFO3 Shape"
blofeld_B4 = 	[
						"LFO3 Speed",
						"LFO3 Sync",
						"LFO3 Delay",
						"OSC1 Oct.",
						"OSC1 Semi.",
						"OSC1 Detu."
blofeld_B5 = 	[
						"OSC1 FM",
						"OSC1 Shape",
						"Bank LSB",
						"OSC1 PW",
						"OSC1 PWM",
						"OSC2 Oct."
blofeld_B6 = 	[
						"OSC2 Semi.",
						"OSC2 Detu.",
						"OSC2 FM",
						"OSC2 Shape",
						"OSC2 PW",
						"OSC2 PWM"
blofeld_B7 = 	[
						"OSC3 Oct.",
						"OSC3 Semi.",
						"OSC3 Detu.",
						"OSC3 FM",
						"OSC3 Shape",
						"OSC3 PW"
blofeld_B8 = 	[
						"OSC3 PWM",
						"Sync",
						"Pitch modu",
						"Glide mode",
						"OSC1 level",
						"OSC1 balance"
blofeld_B9 = 	[
						"RingMod lvl",
						"RngMod balnc",
						"OSC2 level",
						"OSC2 balance",
						"OSC3 level",
						"OSC3 balance"
blofeld_B10 = 	[
						"Noise level",
						"Noise balnc",
						"Noise colour",
						"Undef",
						"Sustain pedal",
						"Glide active"
blofeld_B11 = 	[
						"Sostenuto",
						"Rt (ser/par)",
						"F1 Type",
						"F1 cutoff",
						"F1 resonance",
						"F1 Drive"
blofeld_B12 = 	[
						"F1 Keytrack",
						"F1 env. amount",
						"F1 env. velocity",
						"F1 cutoff mod.",
						"F1 FM",
						"F1 pan"
blofeld_B13 = 	[
						"F1 panMod",
						"F2 Type",
						"F2 cutoff",
						"F2 resonance",
						"F2 Drive",
						"F2 Keytrack"
blofeld_B14 = 	[
						"F2 env. amount",
						"F2 env. velocity",
						"F2 cutoff mod.",
						"F2 FM",
						"F2 pan",
						"F2 panMod"
blofeld_B15 = 	[
						"Amp volume",
						"Amp velocity",
						"Amp mod.",
						"FX1 mix",
						"FX2 mix",
						"FE attack"
blofeld_B16 = 	[
						"FE decay",
						"FE sustain",
						"FE decay2",
						"FE sustain2",
						"FE release",
						"AE attack"
blofeld_B17 = 	[
						"AE decay",
						"AE sustain",
						"AE decay2",
						"AE sustain2",
						"AE release",
						"E3 attack"
blofeld_B18 = 	[
						"E3 decay",
						"E3 sustain",
						"E3 decay2",
						"E3 sustain2",
						"E3 release",
						"E4 attack"
blofeld_B19 = 	[
						"E4 decay",
						"E4 sustain",
						"E4 decay2",
						"E4 sustain2",
						"E4 release",
						"undef"
# Raspberry Pi SPI pin configuration:
RST = 25
# Note the following are only used with SPI:
DC = 24
SPI_PORT = 0
SPI_DEVICE = 0
# 128x64 display with hardware SPI:
disp = Adafruit_SSD1306.SSD1306_128_64(rst=RST, dc=DC, spi=SPI.SpiDev(SPI_PORT, SPI_DEVICE, max_speed_hz=16000000))
# Initialize library.
disp.begin()
# Get display width and height.
width = disp.width
height = disp.height
mid = (width /2, height /2)
# Clear display.
disp.clear()
disp.display()
# Create image buffer.
# Make sure to create image with mode '1' for 1-bit color.
image = Image.new('1', (width, height))
flower = Image.new('1', (width, height))
#Controller bank pages
page = 	[]
for i in range(20):
	page.append(Image.new('1', (width, height)))
#Create Drawing object
draw = []
for i in range(20):
	draw.append(ImageDraw.Draw(page[i]))
#Display logo and wait 2 seconds
flower = Image.open('floweroflife.ppm').convert('1')
disp.image(flower)
disp.display()
#Wait 1s to observe this beautiful logo (:
time.sleep(1)
# Create serial instance on ttyAMA0
ser = serial.Serial('/dev/ttyAMA0', baudrate=38400)
# Clear image buffer by drawing a black filled box.
draw[0].rectangle((0,0,width,height), outline=0, fill=0)
#Garbage
#draw.text((0, 0), "Control ", fill = 255)
#txtsz = draw.textsize("Controller")
#Some variables definitions
message = [0, 0, 0]
storeValue = 0
txtHeight = draw[0].textsize("H")[1]-2
row = 0
coloumn1 = 0
coloumn2 = 127 -  draw[0].textsize("127")[0]
exit = False
#Prepare buffer by drawing each page
#Draw header (same for each pages)
for i in range(20):
	draw[i].text((coloumn1, row), "Midi Channel: ", fill=255)
row += 1
#Draw paramter names (not the same!) on each page
for i in range(len(blofeld_B0)):
	draw[0].text((coloumn1, txtHeight*row), blofeld_B0[i], fill=255)
	row += 1
row = 1
for i in range(len(blofeld_B1)):
	draw[1].text((coloumn1, txtHeight*row), blofeld_B1[i], fill=255)
	row += 1
row = 1
for i in range(len(blofeld_B2)):
	draw[2].text((coloumn1, txtHeight*row), blofeld_B2[i], fill=255)
	row += 1
row = 1
for i in range(len(blofeld_B3)):
	draw[3].text((coloumn1, txtHeight*row), blofeld_B3[i], fill=255)
	row += 1
row = 1
for i in range(len(blofeld_B4)):
	draw[4].text((coloumn1, txtHeight*row), blofeld_B4[i], fill=255)
	row += 1
row = 1
for i in range(len(blofeld_B5)):
	draw[5].text((coloumn1, txtHeight*row), blofeld_B5[i], fill=255)
	row += 1
row = 1
for i in range(len(blofeld_B6)):
	draw[6].text((coloumn1, txtHeight*row), blofeld_B6[i], fill=255)
	row += 1
row = 1
for i in range(len(blofeld_B7)):
	draw[7].text((coloumn1, txtHeight*row), blofeld_B7[i], fill=255)
	row += 1
row = 1
for i in range(len(blofeld_B8)):
	draw[8].text((coloumn1, txtHeight*row), blofeld_B8[i], fill=255)
	row += 1
row = 1
for i in range(len(blofeld_B9)):
	draw[9].text((coloumn1, txtHeight*row), blofeld_B9[i], fill=255)
	row += 1
row = 1
for i in range(len(blofeld_B10)):
	draw[10].text((coloumn1, txtHeight*row), blofeld_B10[i], fill=255)
	row += 1
row = 1
for i in range(len(blofeld_B11)):
	draw[11].text((coloumn1, txtHeight*row), blofeld_B11[i], fill=255)
	row += 1
row = 1
for i in range(len(blofeld_B12)):
	draw[12].text((coloumn1, txtHeight*row), blofeld_B12[i], fill=255)
	row += 1
row = 1
for i in range(len(blofeld_B13)):
	draw[13].text((coloumn1, txtHeight*row), blofeld_B13[i], fill=255)
	row += 1
row = 1
for i in range(len(blofeld_B14)):
	draw[14].text((coloumn1, txtHeight*row), blofeld_B14[i], fill=255)
	row += 1
row = 1
for i in range(len(blofeld_B15)):
	draw[15].text((coloumn1, txtHeight*row), blofeld_B15[i], fill=255)
	row += 1
row = 1
for i in range(len(blofeld_B16)):
	draw[16].text((coloumn1, txtHeight*row), blofeld_B16[i], fill=255)
	row += 1
row = 1
for i in range(len(blofeld_B17)):
	draw[17].text((coloumn1, txtHeight*row), blofeld_B17[i], fill=255)
	row += 1
row = 1
for i in range(len(blofeld_B18)):
	draw[18].text((coloumn1, txtHeight*row), blofeld_B18[i], fill=255)
	row += 1
row = 1
for i in range(len(blofeld_B19)):
	draw[19].text((coloumn1, txtHeight*row), blofeld_B19[i], fill=255)
	row += 1
row = 1
#Display class
class oled(Thread):
	def __init__(self):
		Thread.__init__(self)
	def run(self):
		controller = 0
		currentChannel = 100
		channel = 1
		bankIn = 0
		bank = 0
		init = True
		row = 1
		while not exit:
			try:
				#CC 127 and 126 are coming especially for RPi
				#CC 126 is for controller bank select
				if message[0] > 175 and message[0] < 192 and message[1] == 126:
					bankIn = message[2] 	#Bank info coming from ATmega 328
					if bankIn != 0:
						bank = bankIn / 6	#Real bank value
					else:
						bank = bankIn
					#Display header
					currentChannel = channel
					draw[bank].rectangle((draw[0].textsize("Midi Channel: ")[0], 0, width, txtHeight), outline=0, fill=0)
					draw[bank].text((draw[0].textsize("Midi Channel: ")[0], 0), str(channel), fill = 255)
				#CC 127 stands for midi channel select
				if message[0] > 175 and message[0] < 192 and message[1] == 127 or init:
					if not init:
						channel = message[0]-175
					#Display header
					if currentChannel != channel:
				#Recognize control change and act in consequence
				if init or message[0] > 175 and message[0] < 192 and message[1] != 127 and message[1] != 126:
					controller = message[1] - bankIn
					#Convert int to string for PIL imaging library
					value = str(message[2])
					#Display values on corresponding row to controller number
					draw[bank].rectangle((coloumn2, txtHeight*(controller+row), width,txtHeight*2*(controller+row)), outline = 0, 	fill = 0)
					draw[bank].text((coloumn2, txtHeight*(controller+row)), value, fill=255)
				disp.image(page[bank])
				disp.display()
				#Reset some values for next loop
				init = False
			except:
				print "Error, SOMETHING WENT WRONG (or not)! Here some info bredaaa: \n", sys.exc_info()
				print "Exit flag: ", exit
				sys.exit()
thread1 = oled()
thread1.start()
#Tell debuging user that programm is running
print "Crazy stuff going on..."
while True:
	try:
		i = 0
		while i < 3:
			data = ord(ser.read(1)) # read a byte
			if data >> 7 != 0:
				i = 0      # status byte!   this is the beginning of a midi message!
			message[i] = data
			i += 1
	except:
		exit = True
		thread1.join()
		sys.exit()
Any clue why this issue? :geek:
Thank's!
pcmanbob
Re: Start python on RPi Zero startup
Wed Apr 04, 2018 3:03 pm
Try changing your cron line to this
@reboot python /home/pi/oled/threadingOledMidiA1.py >>/home/pi/error.txt 2>&1
reboot and look in the error.txt file to see if there are any errors listed.
Remember we want information.......................no information no help
The use of crystal balls & mind reading is not supported
Ganjanouille
Wed Apr 04, 2018 3:32 pm
Ok I did that.
error.txtis:
/etc/rc.local: line 15: @reboot: command not found
:o
I ask google for that output but found nothing for the moment.
Thank's for the help
pcmanbob
Wed Apr 04, 2018 3:39 pm
Ok I did that.
error.txtis:
That's because you are attempting to use a cron command in rc.local. remove the lines from rc.local.
the do crontab -e and add the line I suggested.
Ganjanouille
Wed Apr 04, 2018 4:09 pm
So I did the correction. Still don't work (it was correct when I tested it first time)
So know it's become clearer, error.txt content is:
/etc/rc.local: line 19: @reboot: command not found
  File "/home/pi/oled/threadingOledMidiA1.py", line 238, in <module>
  File "/usr/lib/python2.7/dist-packages/PIL/Image.py", line 2312, in open
    fp = builtins.open(filename, "rb")
IOError: [Errno 2] No such file or directory: 'floweroflife.ppm'
Strange is that the file is in the same directory. What else I have to specifiy?
[email protected]:~/oled $ ls
animate.py               beforConvert.png  fractFougere.py   stats.py                threadingOledMidi.py~
ArduiPi_OLED-master      convert.ppm       oledMidi.py       threadingOledMidiA1.py  threadingOledMidi.pyc
ArduiPi_OLED-master.zip  floweroflife.ppm  pointParPoint.py  threadingOledMidi.py
Thank's!
pcmanbob
Wed Apr 04, 2018 4:14 pm
Cron operates in a different environment to the command line, your python program needs to use full paths to all files.
for example
you need to add the full path to floweroflife.ppm
Ganjanouille
Wed Apr 04, 2018 4:20 pm
I just added full path in python script!
Now it's working. Thank's a lot!
