davef21370
Autorun Python
Sun Oct 21, 2012 8:34 am
How can I get a Python program to run on startup?
No keyboard or monitor, just boot the RPi and away it goes.
Apple say... Monkey do !!
eyebee
Re: Autorun Python
Sun Oct 21, 2012 9:33 am
KenT
Re: Autorun Python
Sun Oct 21, 2012 1:18 pm
Just hacked this problem the other day. Answer based on this https://github.com/wireload/screenly-os ... install.sh
Create the folder home/pi/.config/lxsession/LXDE/
/home/pi/.config is already present in the image but you will need to select Show Hidden files in the Filemanager to see it.
In this folder put a file named autostart with one line:
python /home/pi/myprog.py
Pi Presents - A toolkit to produce multi-media interactive display applications for museums, visitor centres, and more
Download from http://pipresents.wordpress.com
milhouse
Re: Autorun Python
Sun Oct 21, 2012 1:35 pm
Which OS? Presumably Raspbian - in which case adding an init.d script is the preferred solution though if you don't require much control over starting/stopping your script and/or just want a really simple solution, then just add the following to the end of /etc/crontab - it will ensure the script starts at startup (running as user root, which you may or may not want, so consider changing that too):
@reboot root /path/to/python/script.py
beautifulsmall
Re: Autorun Python
Sat Nov 17, 2012 6:44 pm
How do I stop Autorun.
Hope this is relevant to the topic , I have a C programme a.out to send data out of the uart and i autologon and autorun the programme by an added line /root/Desktop/a.out in /etc/local.rc
It runs ok from power on but how can I stop it . The only thing that works is Ctrl-alt-del which reboots !!
running raspbian, I can see text but no prompt.
beautifulsmall
Re: Autorun Python
Sat Nov 17, 2012 9:10 pm
rc.local , was the file which runs a.out , the uart sends the data so I know a.out is running but I don't get a prompt and cant get "back in" . any help appreciated.
BlackJack
Re: Autorun Python
Sat Nov 17, 2012 10:27 pm
@beautifulsmall: Any chance you did not start the program asynchronously from ``/etc/rc.local`` so that skript never comes to an end and blocks the startup process‽
Can you stop the program by pressing Ctrl + C at the text screen to get to the text prompt?
while not self.asleep():
    sheep += 1
beautifulsmall
Re: Autorun Python
Sun Nov 18, 2012 9:01 pm
The code runs in a continuous loop bursting 8 bytes every second. Ctrl C displays C^ but has no effect. I can use a linux machine tomorrow to edit the file on the SD card so all is not lost and I will add your suggested code. Many thanks.
