johan_rasp_prog
Writing to gpio
Wed Jan 31, 2018 12:58 pm
I have a Raspberry Pi 3 with Raspbian and I wonder what I need to do to be able to make a software which writes to the gpio addresses? Right now I get segmentation fault even if I run as root.
Can I use Linux in some way or do I have to do a bare metal software? In either way, does someone know a tutorial I can follow?
I want to be able to write to the gpio and the dma controller.
Regards
Johan
jahboater
Re: Writing to gpio
Wed Jan 31, 2018 2:09 pm
Linux/Raspbian.
You can use a library such as wiringPi or pigpio (both of which are pre-installed and ready to go).
Or you can write your own code in C, using the mmap() system call.
I suggest a popular library.
joan
Re: Writing to gpio
Wed Jan 31, 2018 4:15 pm
rados-dataplicity
Contact: Website Facebook Twitter
Re: Writing to gpio
Fri Feb 09, 2018 5:22 pm
From bash command line you can simply do:
echo "5" > /sys/class/gpio/export
echo "out" > /sys/class/gpio/gpio5/direction
echo "1" > /sys/class/gpio/gpio5/value
Ofcourse, adjust parameters such as GPIO pin number as you wish ;)
/sys is your interface between the kernel
I tinker around with Raspberry Pis daily and make sure that people can easily access theirs remotely.
Community outreach @ dataplicity.com
