fulvio
Slice of Pi and Xbee
Wed Oct 17, 2012 11:22 pm
I have purchased a "Slice of Pi" from ModMyPi:
https://www.modmypi.com/shop/slice-of-p ... akout-boad
I have an Xbee module that I'm placing on this breakout.
I have been using a USB breakout board to send serial packets from the Xbee to an Arduino. This was always working just fine by sending a packet to '/dev/ttyUSB0'.
The problem is that now that I have this slice of pi breakout board and I'm not sure what TTY device to use.
This is the current python code I was using:
import socket
import RPi.GPIO as GPIO
import wiringpi
device = "/dev/ttyUSB0"
message = "hello world"
serial = wiringpi.Serial(ttyDevice, 9600)
serial.puts(message)
I wasn't sure what device to set while using the Slice of Pi breakout instead.
Is it /dev/ttyAMA0?
According to this tutorial that's what they were using:
http://www.doctormonk.com/2012/06/raspb ... ensor.html
I tried that and it doesn't send any packets to the Arduino.
Any help would be greatly appreciated.
rudydevolder
Re: Slice of Pi and Xbee
Thu Nov 29, 2012 8:28 pm
Don't forget to free up the Com-port !!! ;) because it's default used/occupied for Console input/output
see:
http://www.hobbytronics.co.uk/raspberry-pi-serial-port
