sbaratheon
Is there anything wrong with this bash script (timelapse)?
Sun Jan 14, 2018 2:25 pm
I've written the following bash script to use the rpi's camera as a timelapse (i didn't use raspistill directly as you can't save the timestamp):
# Note: This script runs at startup (listed in /etc/rc.local)
#!/bin/bash
MINUTES=720
SECONDS_TO_RUN=$((60 * MINUTES))
DELAY=25
while [ "$SECONDS" -lt "$SECONDS_TO_RUN" ]; do
	DATE=$(date +"%H_%M_%S")
	raspistill --nopreview  -o /home/pi/timelapse/$DATE.jpg
	sleep $DELAY
done
The script does appear to run but only for 5 - 6 hours after which it seems to stop taking photos. I know that the rpi has more than enough space to save the photos on so that shouldn't be an issue.
The only thing which comes to mind is the internal $seconds variable - does this exclude time during which the 'sleep' command is running?
Many thanks in advance
Re: Is there anything wrong with this bash script (timelapse)?
Sun Jan 14, 2018 2:32 pm
Where does the $SECONDS variable get set? Where does that variable get updated?
Note:Having anything remotely humorous in your signature is completely banned on this forum.
sbaratheon
Sun Jan 14, 2018 2:47 pm
I was under the impression that $SECONDS was an internal variable (http://tldp.org/LDP/abs/html/internalvariables.html)
Sun Jan 14, 2018 2:58 pm
OK. I'm not sure why your loop terminates and you're dumping any stderr messages into /dev/null by running it from /etc/rc.local.
Did you know that raspistill has a built-in timelapse option? Use that and your only remaining problem is killing it when 720 minutes are over.
-tl, --timelapse : Timelapse mode. Takes a picture every <t>ms. %d == frame number (Try: -o img_%04d.jpg)
rpdom
Sun Jan 14, 2018 3:34 pm
It is. But you might want to set it to zero at the start.
sbaratheon
Sun Jan 14, 2018 3:56 pm
That command saves by the frame number. I need to record the timestamp in the image.
sbaratheon
Sun Jan 14, 2018 3:57 pm
I thought the variable recorded the number of seconds elapsed since the script started running (i.e. it's set at 0 when the script first runs)?
