Iexpress
How to Autorun a Bash .sh script located on optical media when optical media is inserted?
Thu Dec 07, 2017 1:21 am
Hi all, I was wondering how to make a Bash script located on removable optical media run automatically each time the optical disc is inserted within Raspbian?
I was wanting to send raw data to /dev/fb0, to show a custom graphical menu and it's selections via a BASH script.
Does Raspbian Stretch allow Autorun.inf files to run automatically when a disc is inserted?
Thanks!
asandford
Re: How to Autorun a Bash .sh script located on optical media when optical media is inserted?
Thu Dec 07, 2017 1:30 am
Autorun is a Windows thing and not relevant to linux.
External media tends to get mounted automatically, and there must be examples on the web doing what you want.
scruss
Thu Dec 07, 2017 3:08 am
Not merely is Autorun discouraged under Linux, it's actively prevented. Removable media is mounted with the noexec option, which prevents any scripts/binaries being run automatically.
Iexpress
Thu Dec 07, 2017 3:54 am
Thanks for explaining.
Maybe there's a way to use Udev, to check for when media is inserted. Maybe it can run a script and take appropriated action if it finds a certain file on the media.
I would probably name the script on the removable media autorun.sh, which I would like to use to load a series of raw images to /dev/fb0 that change depending on user input, giving an effect of scrolling through a menu.
Thanks again
ghans
Thu Dec 07, 2017 7:17 am
udev seems the way forward. I can't think of anyother mechaanism to trigger scripts on
hotplug events.
ghans
Thu Dec 07, 2017 9:59 am
hotplug events.
ghans
Both of these work:
KERNEL=="sd*", SUBSYSTEMS=="scsi", DRIVERS=="sd", SYMLINK+="sticker",  RUN+="/usr/local/bin/sticker_drive $kernel'"
SUBSYSTEMS=="usb", ATTRS{removable}=="removable", RUN+="/usr/local/bin/sticker_drive $kernel'"
The script that runs is
#!/usr/bin/python
import sys
import logging
import logging.handlers
my_logger = logging.getLogger('sticker_drive')
my_logger.setLevel(logging.DEBUG)
handler = logging.handlers.SysLogHandler(address = '/dev/log')
my_logger.addHandler(handler)
my_logger.debug('Sticker drive active')
my_logger.debug('Argv[0]:'+sys.argv[0])
try:
  my_logger.debug('Argv[1]:'+sys.argv[1])
except:
  pass
import RPi.GPIO as GPIO
from time import sleep
GPIO.setmode(GPIO.BCM)
GPIO.setup(18, GPIO.OUT)
my_logger.debug('Wiggling pin18 started')
for i in range(20):
  GPIO.output(18, 1)
  sleep(0.1)
  GPIO.output(18, 0)
  sleep(0.1)
my_logger.debug('Wiggling pin18 done')
You need to run a command like systemctl to get a long running service started. Udev scripts have a time limit before Udev shoots them dead.
ghans
Thu Dec 07, 2017 10:44 am
DougieLawson wrote:Udev scripts have a time limit before Udev shoots them dead.
Isn't there a way around that ? Like using "at" to schedule your script some seconds into the future ? It seems like no matter how deep you nest your bash scripts udev kills the whole process hierarchy.
ghans
sparkie777
Thu Dec 07, 2017 12:28 pm
did you already try to run the program in a new session?
something like this:
setsid sh -c 'sleep 11; sleep 22; sleep 33' 1>&- 2>&- &
Initially, the new session has no controlling terminal. The calling process will be the only process in the new process group and in the new session. So udev should not get too much chance to kill it :)
rpdom
Thu Dec 07, 2017 12:30 pm
How about having something monitoring a file/directory/pipe and when your udev script pokes some information into that it reacts and does the work, no matter how long it takes, possibly forking off another process to do the actual work.
Thu Dec 07, 2017 12:39 pm
That could be a MQTT publish.
Running an AT job from the udev makes sense.
Starting a systemctl task makes sense.
You just can't fork or spawn a new task directly from the udev script.
rpdom
Thu Dec 07, 2017 12:58 pm
I never suggested that you should.
Thu Dec 07, 2017 1:42 pm
I know, you said "send a message to another process to action the udev event" (paraphrased).
rpdom
Sun Dec 10, 2017 12:27 pm
Exactly :roll:
