zenocon
C code to extract BCM serial number
Mon Oct 01, 2012 2:08 pm
The output of /proc/cpuinfo
Processor	: ARMv6-compatible processor rev 7 (v6l)
BogoMIPS	: 697.95
Features	: swp half thumb fastmult vfp edsp java tls
CPU implementer	: 0x41
CPU architecture: 7
CPU variant	: 0x0
CPU part	: 0xb76
CPU revision	: 7
Hardware	: BCM2708
Revision	: 0002
Serial		: 000000001a5ce8e3
How can I read the serial number reported here direct from the hardware?. I looked through the BCM2835 datasheet, and I can't find a register that reports this. I don't know the linux source tree all that well -- I know the answer is in there somewhere, but I was hoping someone might be able to tell me quickly.
I'm writing in C - and I'd prefer to not call out to an external script to parse the string output from /proc/cpuinfo
Thanks in advance
Narishma
Re: C code to extract BCM serial number
Mon Oct 01, 2012 5:09 pm
Is there a reason you can't just parse it in your C code instead of calling an external script?
Something like:
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
int main(int argc, char **argv)
	FILE *f = fopen("/proc/cpuinfo", "r");
	if (!f) {
		return 1;
	char line[256];
   int serial;
	while (fgets(line, 256, f)) {
		if (strncmp(line, "Serial", 6) == 0) {
			char serial_string[16 + 1];
			serial = atoi(strcpy(serial_string, strchr(line, ':') + 2));
	return fclose(f);
zenocon
Mon Oct 01, 2012 5:11 pm
Sure, I could -- I just wondered what register this serial number is stored in. It would be simpler / more ideal to just read that to get the number.
Narishma
Mon Oct 01, 2012 6:03 pm
zenocon wrote:Sure, I could -- I just wondered what register this serial number is stored in. It would be simpler / more ideal to just read that to get the number.
I don't think you can do that (read a hardware register) on Linux, unless you write a kernel module that reads the register and exposes it to userspace programs, perhaps through a file in /proc. So you would just end up re-implementing /proc/cpuinfo.
DexOS
Mon Oct 01, 2012 7:15 pm
https://github.com/raspberrypi/firmware ... -interface
Its easy under bare metal, but under linux you will most likely need to map it. Take a look pi wiring https://projects.drogon.net/raspberry-pi/wiringpi/
as a example of low level access under the pi and linux.
Batteries not included, Some assembly required.
zenocon
Mon Oct 01, 2012 7:19 pm
Awesome -- thank you! This is very helpful
DexOS wrote:https://github.com/raspberrypi/firmware ... -interface
