Trigo
Crontab on raspian
Sat Mar 18, 2017 5:39 pm
i'm to setting up a raspian running a cloud storage service and i want it to run a script that sees if the service is up and running! I've made the script but it doesn't work with crontab! Can someone help?
Beat psychologically with a stick :?:
Trigo
Re: Crontab on raspian
Sat Mar 18, 2017 8:24 pm
This is the script
#!/bin/sh
APP=$(ps aux | grep -v grep | grep apl)
if [ -z "$APP" ];
then
echo "Restart apl-daemon"
apl daemon
apl start --config /home/pi/path/to/config1.json
apl start --config /home/pi/path/to/config2.json
fi
This is the output from crontab-l
# Edit this file to introduce tasks to be run by cron.
# Each task to run has to be defined through a single line
# indicating with different fields when the task will be run
# and what command to run for the task
# To define the time you can provide concrete values for
# minute (m), hour (h), day of month (dom), month (mon),
# and day of week (dow) or use '*' in these fields (for 'any').#
# Notice that tasks will be started based on the cron's system
# daemon's notion of time and timezones.
# Output of the crontab jobs (including errors) is sent through
# email to the user the crontab file belongs to (unless redirected).
# For example, you can run a backup of all your user accounts
# at 5 a.m every week with:
# 0 5 * * 1 tar -zcf /var/backups/home.tgz /home/
# For more information see the manual pages of crontab(5) and cron(8)
SHELL=/bin/sh
PATH=/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin
# m h dom mon dow command
*/ 5 * * * pi pi /home/pi/watchdog.sh
@reboot pi pi /home/pi/watchdog.sh
File was written on /tmp/crontab.Mi9kwE/crontab
This is the output from cron status
pi@raspberrypi:~ $ systemctl status cron
● cron.service - Regular background program processing daemon
Loaded: loaded (/lib/systemd/system/cron.service; enabled)
Active: active (running) since Sat 2017-03-18 14:13:22 UTC; 6h ago
Docs: man:cron(8)
Main PID: 454 (cron)
CGroup: /system.slice/cron.service
└─454 /usr/sbin/cron -f
pi@raspberrypi:~ $
What should i do! Maybe changing the ownership or the permission of the script? Who can help? I'm really noob at this!
Paeryn
Sat Mar 18, 2017 8:52 pm
Why have you got pi pi in the crontab? There should be 5 paramaters specifiying the time & date (or the specific @reboot taking place of the time & date parameters) and then the program (with arguments) to run. As you have it it will try to run a program called pi with its first argument as pi and your script's filename as the second argument.
Please note that my name doesn't start with the @ character so can people please stop writing it as if it does!
Trigo
Sat Mar 18, 2017 8:59 pm
solved! it looks like there was much space between this* :)
Trigo
Sat Mar 18, 2017 10:57 pm
i'm not able to make it run! :oops: I've got two crontabs one under root and other under pi!
Paeryn
Sat Mar 18, 2017 11:58 pm
Trigo wrote:i'm not able to make it run! :oops: I've got two crontabs one under root and other under pi!
What do your crontab lines look like now? Did you remove the errornous pi pi that you originally had?
What directory is the apl program in, is it in one of the directories that are listed in the PATH variable in the relavent crontab?
Try redirecting stdout & stderr for the command in the crontab so you can see any error messages.
* * * * * /home/pi/watchdog.sh >/home/pi/watchdog.output 2>&1
Trigo
Sun Mar 19, 2017 12:00 am
Like this
Active: active (running) since Sat 2017-03-18 23:48:56 UTC; 7min ago
Docs: man:cron(8)
pi@raspberrypi:~ $ sudo su
root@raspberrypi:/home/pi# systemctl status cron
Active: active (running) since Sat 2017-03-18 23:48:56 UTC; 8min ago
Docs: man:cron(8)
Mar 18 23:50:09 raspberrypi CRON[2144]: (CRON) info (No MTA installed, discarding output)
Mar 18 23:50:09 raspberrypi CRON[2144]: pam_unix(cron:session): session closed for user root
Mar 18 23:55:01 raspberrypi CRON[2234]: pam_unix(cron:session): session opened for user root by (uid=0)
Mar 18 23:55:01 raspberrypi CRON[2233]: pam_unix(cron:session): session opened for user root by (uid=0)
Mar 18 23:55:01 raspberrypi CRON[2241]: (root) CMD (( cd /home/pi/ && sh watchdog.sh ))
Mar 18 23:55:01 raspberrypi CRON[2242]: (root) CMD ( /home/pi/watchdog.sh)
Mar 18 23:55:01 raspberrypi CRON[2234]: (CRON) info (No MTA installed, discarding output)
Mar 18 23:55:01 raspberrypi CRON[2233]: (CRON) info (No MTA installed, discarding output)
Mar 18 23:55:01 raspberrypi CRON[2234]: pam_unix(cron:session): session closed for user root
Mar 18 23:55:01 raspberrypi CRON[2233]: pam_unix(cron:session): session closed for user root
root@raspberrypi:/home/pi# exit
exit
pi@raspberrypi:~ $ storj status
daemon is not running, try: storj daemon
Trigo
Sun Mar 19, 2017 12:12 am
where do i find watchdog.output? how do i view the output?
Paeryn
Sun Mar 19, 2017 12:23 am
You just gave the status of cron, I asked what your crontab looked like (as reported with crontab -l).
I gave watchdog.output as an example filename that would contain the output of the attempted running of your script. It would be created when cron tries running your script and as I explicitly gave the full path to it as being in pi's home directory that is where it would be.
You can view the file when it has been created with whatever you want, or
cat /home/pi/watchdog.output
Trigo
Sun Mar 19, 2017 12:27 am
Paeryn wrote:You just gave the status of cron, I asked what your crontab looked like (as reported with crontab -l).
I'm seeing it! But i'm connected to the pi via ssh! And i would like to open it... i've tried with nano and with less!
Trigo
Sun Mar 19, 2017 12:28 am
It shows nothing...! :?:
Paeryn
Sun Mar 19, 2017 12:37 am
If it's an empty file then no output was generated from the script. Since your script echos some text when it should be running apl then it looks like it hasn't got there. Try putting one right at the start so you can see that the script is at least running. And maybe one to print the value of $APP too.
TracyLBaker
Sun Mar 19, 2017 1:08 am
Each user gets their own crontab. The system has one as well (which is /etc/crontab and edited by hand, not crontab -l).
Users crontabs should look like this (6 fields):
minute hour day_of_month month day_of_week command
The system's crontab (/etc/crontab), has 7 fields and is edited with a text file editor:
minute hour day_of_month month day_of_week user_to_run_command_as command
Some rules:
  • Spaces make a difference -- spacing doesn't.
    Scripts must be executable.
    Full paths to the script should be used in the crontab.
    The script should use full paths to call the other scripts and executables (other than builtins) it uses.
    Cronjobs cannot output stdout or stderr (to the terminal screen) as they are background jobs and have no control over the terminal.
RHCE, Red Hat Academy Professor - Estrella Mountain Community College
2 Pi 4B 4Gb media servers with 48Tb 5 Pi 3 Model B+s: 1 headless media/NFS/SMB server - Raspbian Jessie, 1 Kali Linux w/fruitywifi, 1 headless CentOS 7 webserver, 2 backups
Sun Mar 19, 2017 8:46 am
To log the output of your cron scripts, you should send the output somewhere (cron defaults to trying to mail it, but there is no mail set up for it).
Try
*/ 5 * * * /home/pi/watchdog.sh >>/tmp/watchdog.log 2>&1
@reboot /home/pi/watchdog.sh >>/tmp/watchdog.log  2>&1
and then look at the contents of /tmp/watchdog.log to see why it didn't do what was expected.
[edit]fixed redirection typo
Paeryn
Sun Mar 19, 2017 11:59 am
rpdom wrote:To log the output of your cron scripts, you should send the output somewhere (cron defaults to trying to mail it, but there is no mail set up for it).
Try
*/ 5 * * * /home/pi/watchdog.sh 2>&1 >>/tmp/watchdog.log
@reboot /home/pi/watchdog.sh  2>&1 >>/tmp/watchdog.log
You've got the redirections in the wrong order, you have to redirect stdout to a file before redirecting stderr to stdout. Putting 2>&1 before the file redirection will just result in stderr being redirected to the original stdout, not the subsequent file.
Sun Mar 19, 2017 12:34 pm
Start with
sudo crontab -l
crontab -l
cat /etc/crontab
cat /etc/cron.d/*
cat /etc/cron.daily/*
cat /etc/cron.weekly/*
cat /etc/cron.monthly/*
There's lot of places to put cron's tables.
