make install errors trying to install sapcezero game latest
Posted: Sat Dec 17, 2016 2:28 pm
by Quantu
when i run 'sudo make install' on the game spacezero in /home/pi/spacezero/spacezero it apparently spits out this:
if [ ! -d /usr/local/games ] ; then mkdir -p /usr/local/games ; fi
if [ ! -d /usr/local/share/spacezero ] ; then mkdir -p /usr/local/share/spacezero; fi
if [ ! -d /usr/local/share/spacezero/sounds/ ] ; then mkdir -p /usr/local/share/spacezero/sounds/; fi
if [ ! -d /usr/local/share/spacezero/locales/ ] ; then mkdir -p /usr/local/share/spacezero/locales/; fi
cp ./dat/sounds/*.ogg /usr/local/share/spacezero/sounds/
cp ./dat/letterfrequencytable /usr/local/share/spacezero
cp ./dat/locales/*.txt /usr/local/share/spacezero/locales/
cp ./bin/spacezero /usr/local/games
cp: can not acuire state of ‘./bin/spacezero’ : file or folder does not exist
Makefile:59: recipe for target 'install' failed
make: *** [install] error 1
i translated some stuff of my language to english.
is there a possibility to fix?
Re: make install errors trying to install sapcezero game lat
Posted: Mon Dec 19, 2016 4:20 pm
by topguy
If the binary isnt there then you havent built it or it wasnt built correctly ?
Have you done "make" first ?
Posted: Sat Dec 24, 2016 12:54 pm
by Quantu
it should run make before it runs install target thats why the sudo make install
or am i completely wrong?
Posted: Sat Dec 24, 2016 4:35 pm
by B.Goode
Doesn't that depend entirely on how the maintainer has written the Makefile?
Those sorts of dependencies can be encoded in a Makefile: I'm not sure there is any law that says they must be. (And I can think of good practical reasons why you might want the make and make install to be separate steps.)
What does the maintainer's documentation have to say about installation?
Posted: Sun Dec 25, 2016 11:44 am
by Quantu
this:
SpaceZero v0.86
INSTALLATION
Software Requirements
Libraries to compile SpaceZero:
libgtk2.0-dev
libglib2.0-dev
libopenal-dev
libalut-dev
libvorbis-dev
Compiling and Installing
untar the gzipped file spacezero-X.XX.tar.gz in a temporary file with the
command:
$ tar zxvf spacezero-X.XX.XX.tar.gz
A tree structure directory has been created. Change to the spacezero
directory and simply type:
$make spacezero
and as root:
#make install
for a full system instalation.
The necessary executable file is copied to /usr/local/games.
The necessary data files are copied to /usr/local/share/spacezero.
A config directory is created in your home directory as .spacezero
Add /usr/local/games to your path.
You can change the default target directories in Makefile.
Miscellaneous Notes
gtk 1.2 library
For old machines you can compile against gtk1.2 library doing:
$make gtk12
instead of $make spacezero
Disclaimer
** This is part of the SpaceZero program
** Copyright(C) 2006-2013 M.Revenga
** This program is free software; you can redistribute it and/or modify
** it under the terms of the GNU General Public License (version 3), or
** (at your option) any later version, as published by the Free Software
** Foundation.
** This program is distributed in the hope that it will be useful,
** but WITHOUT ANY WARRANTY; without even the implied warranty of
** MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
** GNU General Public License for more details.
** You should have received a copy of the GNU General Public License
** along with this program; if not, write to the Free Software
** Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
Posted: Sun Dec 25, 2016 11:50 am
by Quantu
and this is makefile code:
CC=gcc
BINDIR= ./bin
DATADIR= ./dat
SOUNDDIR= $(DATADIR)/sounds
SRCPATH= ./src/
CONFIGDIR=$(HOME)/.spacezero
RECORDFILE=$(CONFIGDIR)/record
# The binary executable will be copied in the next directory.
INSTALL_DIR=/usr/local/games
# All data files will be copied in the next directory.
# tar.gz
INSTALL_DATA_DIR=/usr/local/share/spacezero
# DEB pkg
#INSTALL_DIR=/usr/games
#INSTALL_DATA_DIR=/usr/share/spacezero
SOUNDFLAGS= -lopenal -lalut -lvorbisfile
GTKFLAGS=`pkg-config --cflags gtk+-2.0`
GTKLIBS=`pkg-config --libs gtk+-2.0`
#GTKLIBS12=`gtk-config --cflags`
#GTKFLAGS12=`gtk-config --libs`
CFLAGS= -Wall -O3 --pedantic -I./include -DDATADIR=\"$(DATADIR)\" -DINSTALL_DATA_DIR=\"$(INSTALL_DATA_DIR)\"
LDFLAGS= -lm -lpthread $(SOUNDFLAGS) $(GTKLIBS)
# DEB pkg
#CFLAGS += `dpkg-buildflags --get CFLAGS`
#LDFLAGS += `dpkg-buildflags --get LDFLAGS`
CFLAGS12= -Wall -O3 -I./include -DGTK12 -DDATADIR=\"$(DATADIR)\" -DINSTALL_DATA_DIR=\"$(INSTALL_DATA_DIR)\"
LDFLAGS12= -lm -lpthread $(SOUNDFLAGS) $(GTKLIBS12)
PROGFLAGS=$(CFLAGS) -pg
PROFCC= $(CC) -pg
PROGRAM=$(BINDIR)/spacezero
SOUND_OBJS= $(SRCPATH)sound.o $(SRCPATH)streamsound.o
SOUND_SRCS= $(SRCPATH)sound.c $(SRCPATH)streamsound.c
PROGRAM_OBJS=$(SRCPATH)spacezero.o $(SRCPATH)objects.o $(SRCPATH)ai.o $(SRCPATH)save.o $(SRCPATH)shell.o $(SRCPATH)spacecomm.o $(SRCPATH)help.o $(SRCPATH)comm.o $(SRCPATH)graphics.o $(SRCPATH)functions.o $(SRCPATH)data.o $(SRCPATH)menu.o $(SRCPATH)sectors.o $(SRCPATH)clock.o $(SRCPATH)statistics.o $(SRCPATH)randomnamegen.o $(SRCPATH)locales.o $(SRCPATH)players.o $(SRCPATH)snow.o $(SOUND_OBJS)
PROGRAM_SRCS=$(SRCPATH)spacezero.c $(SRCPATH)objects.c $(SRCPATH)ai.c $(SRCPATH)save.c $(SRCPATH)shell.c $(SRCPATH)spacecomm.c $(SRCPATH)help.c $(SRCPATH)comm.c $(SRCPATH)graphics.c $(SRCPATH)functions.c $(SRCPATH)data.c $(SRCPATH)menu.c $(SRCPATH)sectors.c $(SRCPATH)clock.c $(SRCPATH)statistics.c $(SRCPATH)randomnamegen.c $(SRCPATH)locales.c $(SRCPATH)players.c $(SRCPATH)snow.c $(SOUND_SRCS)
all: dirs spacezero
spacezero: $(PROGRAM_OBJS)
$(CC) $(PROGRAM_OBJS) $(LDFLAGS) $(CFLAGS) -g -o $(PROGRAM)
gtk12: $(PROGRAM_SRCS)
$(CC) `gtk-config --cflags` $(PROGRAM_SRCS) $(LDFLAGS12) $(CFLAGS12) -g -o $(PROGRAM) `gtk-config --libs`
install:
-if [ ! -d $(INSTALL_DIR) ] ; then mkdir -p $(INSTALL_DIR) ; fi
-if [ ! -d $(INSTALL_DATA_DIR) ] ; then mkdir -p $(INSTALL_DATA_DIR); fi
-if [ ! -d $(INSTALL_DATA_DIR)/sounds/ ] ; then mkdir -p $(INSTALL_DATA_DIR)/sounds/; fi
-if [ ! -d $(INSTALL_DATA_DIR)/locales/ ] ; then mkdir -p $(INSTALL_DATA_DIR)/locales/; fi
cp $(SOUNDDIR)/*.ogg $(INSTALL_DATA_DIR)/sounds/
cp $(DATADIR)/letterfrequencytable $(INSTALL_DATA_DIR)
cp $(DATADIR)/locales/*.txt $(INSTALL_DATA_DIR)/locales/
cp $(PROGRAM) $(INSTALL_DIR)
@echo executable files copied to: $(INSTALL_DIR)
@echo data files copied to: $(INSTALL_DATA_DIR)
uninstall:
-rm $(INSTALL_DIR)/spacezero
-if [ -d $(INSTALL_DATA_DIR) ] ; then rm -r $(INSTALL_DATA_DIR); fi
dirs:
-if [ ! -d $(BINDIR) ] ; then mkdir $(BINDIR) ; fi
-if [ ! -d $(CONFIGDIR) ] ; then mkdir $(CONFIGDIR) ; fi
-if [ ! -f $(RECORDFILE) ] ; then touch $(RECORDFILE) ; fi
clean:
rm -f src/*.o bin/spacezero
rm -f core
mrproper: clean
rm -f src/*~ include/*~
.c.o:
$(CC) $(CFLAGS) $(LDFLAGS) $(GTKFLAGS) -c $< -o $@
Posted: Sun Dec 25, 2016 12:08 pm
by B.Goode
$make spacezero
and as root:
#make install
Seems clear to me. What happens if you try that?
Posted: Tue Jan 03, 2017 10:02 am
by Quantu
$make spacezero
and as root:
#make install
It says it cant find /bin/spacezero or some
And then recipe for target 'spacezero' failed
Posted: Tue Jan 03, 2017 10:41 am
by topguy
Then that was the error message this thread should have started with. If you cant build the software, why should the install work.
make clean
make spacezero
Posted: Wed Jan 04, 2017 11:15 am
by B.Goode
$make spacezero
and as root:
#make install
You haven't specified where you got the download. For the purposes of assisting I downloaded the copy linked from http://spacezero.sourceforge.net/
Simply attempting the make spacezero process results in this:
/usr/bin/ld: ./src/graphics.o: undefined reference to symbol 'XListFonts'
//usr/lib/arm-linux-gnueabihf/libX11.so.6: error adding symbols: DSO missing from command line
collect2: error: ld returned 1 exit status
Makefile:53: recipe for target 'spacezero' failed
make: *** [spacezero] Error 1
Using an internet Search tool to lookup that error suggests that the default behaviour of the linker may have changed since the Developer last released the package over 3 years ago.
Adding -lX11 to the LDFLAGS definition in the Makefile fixes this
LDFLAGS= -lm -lpthread -lX11 $(SOUNDFLAGS) $(GTKLIBS)
(This may not be the best/approved solution, but it works.)
Rebuilding with that version of the Makefile completes without error, and there is now an executable in the bin directory -
gcc  ./src/spacezero.o ./src/objects.o ./src/ai.o ./src/save.o ./src/shell.o ./src/spacecomm.o ./src/help.o ./src/comm.o ./src/graphics.o  ./src/functions.o ./src/data.o ./src/menu.o ./src/sectors.o ./src/clock.o  ./src/statistics.o ./src/randomnamegen.o ./src/locales.o ./src/players.o ./src/snow.o ./src/sound.o  ./src/streamsound.o   -lm -lpthread -lX11 -lopenal -lalut -lvorbisfile `pkg-config --libs gtk+-2.0`  -Wall -O3 --pedantic -I./include -DDATADIR=\"./dat\" -DINSTALL_DATA_DIR=\"/usr/local/share/spacezero\" -g -o ./bin/spacezero
pi@rpi2b ~/Quantu/spacezero $ ls -al bin
total 376
drwxr-xr-x 2 pi pi   4096 Jan  4 11:02 .
drwxr-xr-x 7 pi pi   4096 Jan  4 10:49 ..
-rwxr-xr-x 1 pi pi 376452 Jan  4 11:02 spacezero
I have no interest in Games Playing so I have not run the sudo make install step because I don't want this game on my system. But I see no reason why it would no install.
Lessons from this:
1. Developers of free software sometimes adopt a 'Release and Forget' strategy and don't continually adapt their code or instructions for subsequent changes in the environment in which their code runs.
2. Giving the full text of error messages is more helpful than simply saying "it didn't work"
