btb5987
Tachometer
Thu Nov 10, 2016 4:04 pm
Hey,
I am new to using the raspberry Pi but have a project I want to do. I need to display the RPMs of an electric motor on a digital gauge(digital tachometer) but not sure how to set it up. Any thing helps!
dividuum
Re: Tachometer
Mon Nov 14, 2016 9:11 pm
You might have a look at my program info-beamer. There is example code for it that displays gauges that you can control remotely by sending udp packets to info-beamer.
Here is what a user build with that for his boat: https://www.youtube.com/watch?v=s6YJ4oqvQZM
info-beamer hosted - A user and programmer friendly digital signage platform for the Pi: https://info-beamer.com/hosted
DavidS
Re: Tachometer
Mon Nov 14, 2016 10:14 pm
Take a disk, cut a small slit in it, put Laser diod on one side, photosensor on other side, count time between pulses, calculate and display.
