# -*- coding: utf-8 -*-
from selenium import webdriver
from selenium.webdriver.common.by import By
from selenium.webdriver.common.keys import Keys
from selenium.webdriver.support.ui import Select
from selenium.common.exceptions import NoSuchElementException
from selenium.common.exceptions import NoAlertPresentException
import unittest, time, re
class Destavez(unittest.TestCase):
def setUp(self):
self.driver = webdriver.Firefox()
self.driver.implicitly_wait(30)
self.base_url = "http://192.168.1.1/"
self.verificationErrors = []
self.accept_next_alert = True
def test_destavez(self):
driver = self.driver
driver.get(self.base_url + "/")
driver.find_element_by_name("username").clear()
driver.find_element_by_name("username").send_keys("Home_admin")
driver.find_element_by_xpath("//tr[3]/td[2]/input").clear()
driver.find_element_by_xpath("//tr[3]/td[2]/input").send_keys("passadmin")
driver.find_element_by_link_text("Ok").click()
driver.find_element_by_link_text("Reiniciar").click()
def is_element_present(self, how, what):
try: self.driver.find_element(by=how, value=what)
except NoSuchElementException as e: return False
return True
def is_alert_present(self):
try: self.driver.switch_to_alert()
except NoAlertPresentException as e: return False
return True
def close_alert_and_get_its_text(self):
try:
alert = self.driver.switch_to_alert()
alert_text = alert.text
if self.accept_next_alert:
alert.accept()
else:
alert.dismiss()
return alert_text
finally: self.accept_next_alert = True
def tearDown(self):
self.driver.quit()
self.assertEqual([], self.verificationErrors)
if __name__ == "__main__":
unittest.main()
I have put this file on
/var/script, than
and give me this errors
root@raspberrypi:/var/script# python destavez.py
E
ERROR: test_destavez (__main__.Destavez)
File "destavez.py", line 12, in setUp
File "/usr/local/lib/python2.7/site-packages/selenium/webdriver/firefox/webdriver.py", line 80, in __init__
self.binary, timeout)
File "/usr/local/lib/python2.7/site-packages/selenium/webdriver/firefox/extension_connection.py", line 52, i n __init__
self.binary.launch_browser(self.profile, timeout=timeout)
File "/usr/local/lib/python2.7/site-packages/selenium/webdriver/firefox/firefox_binary.py", line 68, in laun ch_browser
self._wait_until_connectable(timeout=timeout)
File "/usr/local/lib/python2.7/site-packages/selenium/webdriver/firefox/firefox_binary.py", line 99, in _wai t_until_connectable
"The browser appears to have exited "
WebDriverException: Message: The browser appears to have exited before we could connect. If you specified a lo g_file in the FirefoxBinary constructor, check it for details.
