vbit-pi
Stop Program after so long?
Sat Jun 11, 2016 11:41 pm
I've recently been experimenting with Peter Kwan's Vbit-Pi, but noticed that the program (./go) often gets stuck or freezes after an hour or two of running. So I was wondering how I could modify the code so that every half hour or hour the program restarts?
Thanks in advance.
epoch1970
Re: Stop Program after so long?
Wed Jun 15, 2016 9:09 am
You could try to restart the program from a cron.d command running every 30 mins.
RaTTuS
Wed Jun 15, 2016 9:42 am
sudo kill -HUP pid
Covfefe
vbit-pi
Wed Jun 15, 2016 6:48 pm
epoch1970 wrote:You could try to restart the program from a cron.d command running every 30 mins.
How? The pid is always Changing.
epoch1970
Wed Jun 15, 2016 8:46 pm
With pidof or pgrep, maybe?
swampdog
Thu Jun 16, 2016 12:25 am
There's a myriad of ways to achieve that. The key is to obtain the correct PID. The bash shell variable "$!" will contain it. Wrap the 'go' command inside some shell script. Here's a generic example..
$ cat z-app
#!/bin/bash
f_exit ()
 echo "cleanup here"
f_trap ()
 echo "*** signal ***" 1>&2
trap 'f_exit'		0
trap 'f_trap;exit'	1 2 3 15
echo "Child BEG"
sleep 10
echo "Child END"
The above equates to the 'go' app. It's just a bit of shell script which gives you a hint as to what will be happening inside 'go' when 'z-foo', your wrapper script (below), is executed..
$ cat z-foo
#!/bin/bash
echo "Parent BEG"
E="z-app"
./"$E" &
P="$!"
fcp_ps ()
 ps -ef | grep -v grep | grep "$P" | grep "$E"
fcp_ps
sleep 5
R=`fcp_ps`
[ -z "$R" ] || {
	echo "Kill $P"
	kill "$P"
	sleep 1
echo "Parent END"
Simply..
$ ./z-foo
..to see the effect. Just for fun, I've left a bug in "fcp_ps". ie: what happens if 'go/z-app' spawns another copy of itself?
vbit-pi
Thu Jun 16, 2016 5:11 pm
Thanks, that's all I need. I've got it going now and the script no longer freezes!
