skywatch
Pi-toPi communication via SSH possible?
Sun Feb 21, 2016 7:45 pm
I would like to know if it is possible to have a pi automatically SEND a command over SSH to another machine when a certain condition occurs.
Lets say if the temperature gets too hot then the pi can send a shutdown signal to a heater or server via an SSH link.
I would assume it can be done, but how would you do this in practice? (I know about the measurement side, it's just how to send a given SSH command from the pi I am stuck with). :?:
Thanks if you can help!
Skywatch.
joan
Re: Pi-toPi communication via SSH possible?
Sun Feb 21, 2016 7:51 pm
ssh otherpi command
where otherpi is the host name or IP address and command should be quoted if it has spaces.
This assumes you have the needed keys at otherpi to allow auto log in.
skywatch
Sun Feb 21, 2016 8:00 pm
So a simple bash/cron script is all I need then?
So it would be ......
SSH 192.168.x.x "sudo poweroff"
Thank you! :D
