susan.pryce
Shutting down
Fri Aug 03, 2012 5:13 am
I am complete novice. I received an sd card with Debian wheezy preloaded. All started up fine. However when I click on red power button right screen the only options are log off or reboot. There is no shutdown option offered. So how do I shut down my pi without turning off power.
joan
Re: Shutting down
Fri Aug 03, 2012 7:54 am
I use
sudo shutdown -hP now
Off course on the Pi this will not remove the power but it safely shuts down the system.
I have the text in a file called off in /usr/local/bin
[email protected]:~$ cat /usr/local/bin/off
#!/bin/bash
To make the file executable you need to
sudo chmod +x /usr/local/bin/off
You can then just type off to shutdown your Pi.
pjc123
Re: Shutting down
Fri Aug 03, 2012 11:40 am
susan.pryce wrote:I am complete novice. I received an sd card with Debian wheezy preloaded. All started up fine. However when I click on red power button right screen the only options are log off or reboot. There is no shutdown option offered. So how do I shut down my pi without turning off power.
As a side note, the graphical shutdown option is only available when you log in as root.
My Raspberry Pi Project Page:
https://www.flaminghellmet.com/launch/
jdbennet
Re: Shutting down
Fri Aug 03, 2012 11:50 am
Just make sure you umount before you halt. The FAT32 boot partition is easily corrupted.
