alexham
Would Debian "squeeze" work on PC
Fri Jul 06, 2012 1:01 pm
Hi, Guys,
Still waiting for my Raspberry - ordered on 21 June and I am wondering if Debian "Squeeze" would work on a PC. For instance, can I install it on a CD and boot up from it just to see what to expect?
Many thanks,
Alex
RaTTuS
Re: Would Debian "squeeze" work on PC
Fri Jul 06, 2012 1:09 pm
debian squeeze [and wheezy] work on PC's - not the image for the RPi as it's a completely different processor
the qemu emulators are closest to what to expect
Covfefe
Nr90
Fri Jul 06, 2012 1:10 pm
Yes,
You can run Debian on your PC, however not the exact image as distributed for the Pi. The Pi runs on ARM hardware. Your PC runs on x86.
Debian does images for both and I believe you can try one from a USB drive. Have a look at:
http://www.debian.org/distrib/
bredman
Fri Jul 06, 2012 1:18 pm
You can run an emulated version of a Raspberry Pi on a Windows PC to get a good idea of what you will see when you get your real Raspberry Pi.
For a version with Debian Squeeze, see the third post in this thread
www.raspberrypi.org/phpBB3/viewtopic.php?f=26&t=5743
Joe Schmoe
Fri Jul 06, 2012 1:31 pm
I think it should be made clear, when we answer this sort of (repeating) post, that there are two distinct ways of interpreting (and thus answering) the question:
1) Can I run a Linux/Debian/like thing on my x86 PC (natively) - to get myself familiar with Linux stuff in general?
2) Can I run the Pi system (which is a heavily modified/customized version of stock Debian) on my x86 PC (via some sort of emulator software)?
The answer to both questions is, clearly, "Yes, but in very different ways".
aaa801
Fri Jul 06, 2012 9:18 pm
Yes to both,
To run debian on your pc
http://unetbootin.sourceforge.net/
just set it to make a bootable live debian
