goglobal
Record a string with button with a time.sleep(3600)?
Thu May 27, 2021 11:38 am
Hello everyone,
I am doing a test. I have raspberry pi zero with a temperature sensor that gets readings every one hour. The code is inside a while loop.
while True:
	#here is the code for reading temps
	if button.is_pressed:
		data = 'yes'
	else:
		data = 'no'
	print(data)
	time.sleep(3600)
So, when I do not press the button I continuously get every one hour the string "no". The issue I have is that even when I press the button I still get "no". Because, I am guessing, I need to press the button at the time that the while loop wakes up.
Is there a way to have a button that is constantly checking if pressed WHILST having a time.sleep(3600)?
thagrol
Re: Record a string with button with a time.sleep(3600)?
Thu May 27, 2021 3:31 pm
Hello everyone,
while True:
		data = 'yes'
	else:
		data = 'no'
	print(data)
	time.sleep(3600)
Yep.
Use a call back. You don't say which library you're using or which language so it's hard to give an example. There's probably an example in the docs for the GPIO library you're using though.
I'm a volunteer. Take me for granted or abuse my support and I will walk away
All advice given is based on my experience. it worked for me, it may not work for you.
Need help? https://github.com/thagrol/Guides
goglobal
Thu May 27, 2021 4:32 pm
Thanks for the reply @thagrol. Apologies for not clarifying. I am using Python and the library I am using is GPIOZERO. I need to have a look around for a callback. I have never used one so I am currently unsure what it is!
B.Goode
Thu May 27, 2021 5:23 pm
The documentation you need for gpiozero is probably here - https://gpiozero.readthedocs.io/en/stab ... tml#button
You probably won't see 'callback' explicitly mentioned there, but that's likely to be what the methods named wait_for_* and when_* are using behind the scenes.
thagrol
Thu May 27, 2021 10:25 pm
You (OP) won't. The method you're looking for is probably Button.when_pressed(). There's an example here: https://gpiozero.readthedocs.io/en/stab ... tml#button
pcmanbob
Fri Jul 30, 2021 1:54 pm
There are a couple of things to take in to consideration ,
1. You will be updating data to " Yes " from within a function , so you need to add a " global data " as the first so that the data variable in the main program loop is updated by the function.
2. You will need to reset data to " No " on each loop as the function call when the button is pressed will only update it to " Yes ".
like this
from gpiozero import Button
import time
def pressed():
    global data
    data = "Yes"
button = Button(21)
button.when_pressed = pressed
data = "No"
while True:
    print(data)
    data = "No"
    time.sleep(4)
