DarkElvenAngel
Writing control characters to screen
Thu Jun 10, 2021 7:01 pm
Hello Everyone,
This is an odd question I know but I'm assuming there is a standard way to do this?
For example if I press <Backspace> the cursor will move back one space but it I want to write the character for backspace instead how is this handled? (I'm thinking over a serial link) My current thought is to preceded the control character with <Esc> this works fine but what is the standard way to do this?
This is for my PT52 project on the Pico
rpdom
Re: Writing control characters to screen
Thu Jun 10, 2021 7:41 pm
I know that pressing Ctrl-V first works in some situations.
Like typing echo "fish then Ctrl+V then Ctrl-M then chips" and Enter will print "fish", then do a CR and print "chips" over the top.
Unreadable squiggle
DarkElvenAngel
Fri Jun 11, 2021 3:13 am
I gave that a try and it does work but not in the way I was thinking maybe it's a bash thing but I got echo "fish^Mchips" For my use case I was thinking it would have a musical note not ^M. I was think like a card game would want to display suits for the cards as an example.
swampdog
Fri Jun 11, 2021 5:15 am
I can't help with the pico but in a normal terminal..
foo@pi18:~ $ echo "foo^Mbar"
bar
foo@pi18:~ $ echo "foo^Mbar" | hexdump -Cv
00000000  66 6f 6f 0d 62 61 72 0a                           |foo.bar.|
00000008
foo@pi18:~ $ echo -n "foo^Mbar" | hexdump -Cv
00000000  66 6f 6f 0d 62 61 72                              |foo.bar|
00000007
..noting that ctrl-V is esc-v when in 'nano'.
Trouble is, it depends on the terminal capabilities. Consider this..
foo@foo:~$ cat c.c
#include <stdio.h>
static const char       ESC=27;
static const char       CH='A', /*up*/
                        CD='B', /*down*/
                        CR='C', /*right*/
                        CL='D', /*left*/
                        HO='H', /*home*/
                        CE='J', /*clear*/
                        MV='Y'; /*move*/
int
main()
 printf("%c%c%c%c%s",ESC,HO,ESC,CE,"abc");
 fflush(stdout);
 printf("%c%c%s",ESC,CD,"def");
 printf("%c%c%c%c%s",ESC,MV,' '+2,' '+10,"ghi");
 fflush(stdout);
 putchar('\n');
 return 0;
..it will not behave until it has the expected terminal (in this case VT52). Thus to see it work..
$ sudo apt-get install xterm
$ xterm -ti vt52 -tn vt52
$ echo $TERM
vt52
..and run the above within that..
abc
   def
          ghi
foo@foo:~$
I picked VT52 because it's about the simplest to implement yourself but there is nothing stopping you inventing your own if both ends of the link are talking to your "apps".
DarkElvenAngel
Fri Jun 11, 2021 5:22 am
bar
00000008
00000007
foo@foo:~$ cat c.c
#include <stdio.h>
                        CD='B', /*down*/
                        CR='C', /*right*/
                        CL='D', /*left*/
                        HO='H', /*home*/
                        CE='J', /*clear*/
                        MV='Y'; /*move*/
int
main()
 fflush(stdout);
 fflush(stdout);
 putchar('\n');
 return 0;
$ echo $TERM
vt52
abc
   def
          ghi
foo@foo:~$
I have to try that my Pico project emulates a VT52.
I have set up if you send ESC and then send another control character the glyph will be displayed and it will not do it's function.
