gordon77
Pico pwm duty range
Fri May 07, 2021 8:16 am
Why does this example say the range is 0 to 65025 when 0 to 65535 appears to work ?
https://projects.raspberrypi.org/en/pro ... the-pico/7
joan
Re: Pico pwm duty range
Fri May 07, 2021 8:46 am
I think it is just an example. Does it say it's the maximum range permitted.
Indeed it does. A mistake then.
B.Goode
Fri May 07, 2021 9:35 am
{ misunderstanding - removed }
gordon77
Fri May 07, 2021 10:42 am
The generic uPython docs just say 'an integer'.
https://docs.micropython.org/en/latest/ ... hlight=pwm
Perhaps it should be raised as a Documentation Issue here: https://github.com/raspberrypilearning/ ... issues/new
Cheers, it also says "value in the range 0 to 65535 inclusive." :D
B.Goode
Fri May 07, 2021 11:16 am
gordon77
Fri May 07, 2021 3:36 pm
Pedantically, isn't that for the Duty Cycle, not the Frequency?
Where did it say it was the frequency ?
B.Goode
Fri May 07, 2021 3:54 pm
Apologies. I misread the original Project page, which begins a paragraph talking about frequency (in bold type) and then segues into talking about duty cycle with no similar emphasis.
The salient point is that there seems to be no justification for the limit implied in the Project text.
