Alex7
Cannot autostart supercollider on RPi4
Wed Apr 21, 2021 10:36 am
Hello everybody,
I would like to start my supercollider code right after Pi boots.
If I put in this into the terminal:
sudo /usr/local/bin/sclang /home/pi/Desktop/mycode.scd
or
sudo lxterminal -e /usr/local/bin/sclang /home/pi/Desktop/mycode.scd
it works without a problem. However I cannot get it to start on boot. I have went through multiple threads like:
https://community.blokas.io/t/supercoll ... -sh/246/34
or the whole approach suggested here:
https://github.com/supercollider/superc ... ERRY_PI.md
none of the solutions seems to do it. I tried:
adding this into crontab -e:
@reboot sleep 20 && sudo lxterminal -e /usr/local/bin/sclang /home/pi/Desktop/mycode.scd
or adding the same into
sudo nano /etc/xdg/lxsession/LXDE-pi/autostart
both with and without sleep
Would anyone know what am I doing wrong ? I am not having these issues when I try to run other stuff.
Thank you for any possible suggestions !!
Alex
klricks
Re: Cannot autostart supercollider on RPi4
Wed Apr 21, 2021 1:42 pm
A sleep command can't be used directly in autostart as each command is executed independently..... so sleep will do nothing.
Instead make a bash script and call the bash script from autostart.
#!/bin/bash
sleep 20
For autostart details see: viewtopic.php?f=66&t=294014
Why use sudo?
If your script requires network then try setting the wait for network on boot option in sudo raspi-config
