CharlyDelta
.sh at startup (Solved)
Wed May 23, 2018 3:12 am
Hello..
I try to make the leds (BrightPi) turn on when starting the RPI.
In command line, sudo ./led.sh works.
I created a bash script :
#! /bin/bash
 i2cset -y 1 0x70 0x00 0xa5
i2cset -y 1 0x70 0x09 0x0f
i2cset -y 1 0x70 0x01 0x32
i2cset -y 1 0x70 0x03 0x32
i2cset -y 1 0x70 0x06 0x32
i2cset -y 1 0x70 0x08 0x32
exit
chmod a+x led.sh
chmod 777 led.sh
/home/pi/.config/lxsession/LXDE-pi/autostart
@lxpanel --profile LXDE-pi
@pcmanfm --desktop --profile LXDE-pi
@xscreensaver -no-splash
@point-rpi
@bash sudo /home/pi/led.sh
What's wrong with that ?,... any idea ?
CharlyDelta
Re: .sh at startup
Thu May 24, 2018 12:17 pm
Is there another way to make the leds light up at startup??
thagrol
Re: .sh at startup
Thu May 24, 2018 12:54 pm
/home/pi/.config/lxsession/LXDE-pi/autostart does run at start up. It runs when the pi user logs in to the GUI desktop. WIth no user logged in it won't run. With the pi user logged into to more than one desktop (console and vnc) it'll run more than once.
Make sure your script can be run by everyone then try adding
/home/pi/led.sh &
to /etc/rc.local but make sure you put it above the line that reads "exit 0"
Note to self: don't feed the trolls
If I've asked you a question, please answer it. I'm unlikely to be able to help without that information.
CharlyDelta
Re: .sh at startup
Fri May 25, 2018 2:49 am
Thanks, it's working!!
CharlyDelta
Re: .sh at startup (partially closed)
Sun May 27, 2018 12:44 pm
Now that the lights turn on automatically when the RPI starts, how can I turn them off when the RPI shutdown?
I tried in rc6.d without success. Another place to insert the script?
Thank you
CharlyDelta
Sun May 27, 2018 1:14 pm
The more I search, the more complicated it seems.
It is only a question of executing a script somewhere in the process of closing the RPI in order to interrupt the current in a pine of the GPIO because the leds remain lit after the closing of the RPI
Any leads?
thagrol
Tue May 29, 2018 6:19 pm
Th more I search, the more complicated it seems.
Any leads?
If all you need to do is switch a pin to low on shutdwon, the gpio-poweroff device try overlay might be enough. From https://github.com/raspberrypi/firmware ... ays/README
Info:   Drives a GPIO high or low on poweroff (including halt). Enabling this
        overlay will prevent the ability to boot by driving GPIO3 low.
Load:   dtoverlay=gpio-poweroff,<param>=<val>
Params: gpiopin                 GPIO for signalling (default 26)
        active_low              Set if the power control device requires a
                                high->low transition to trigger a power-down.
                                Note that this will require the support of a
                                custom dt-blob.bin to prevent a power-down
                                during the boot process, and that a reboot
                                will also cause the pin to go low.
        input                   Set if the gpio pin should be configured as
                                an input.
        export                  Set to export the configured pin to sysfs
Give that you're not controlling the pi's power you can probably ignore note about active low
Whether this can be used will depend on your LED circuit and driving software.
CharlyDelta
Wed May 30, 2018 10:26 am
G0od idea ! Thank you !
