spike77
Cross-Development: C64 Assembler with the RPi?
Sat Nov 25, 2017 9:24 pm
Hello everyone :-)
i'd like to do some cross-development with the Raspberry Pi. I want to write programms in C64 Assembly Language. But in order to do so, i need at least one of the Cross-Assemblers that exist. After looking through the software repositories for Rasbian i cannot find, any C64-Cross-Assembler. I planned to test the written code with the VICE Emulator.
Do you know any programs that might be helpful for this purpose? For example do you know a specific Editor that is highlighting C64-Assembler-Syntax, maybe?
I am using a Raspberry Pi 3 with the latest Rasbian.
Thanks alot!
Spike
The Traveler
Re: Cross-Development: C64 Assembler with the RPi?
Sat Nov 25, 2017 9:47 pm
Here ya go: https://github.com/cliffordcarnmo/c64-devkit
I don't think you're going to find an 8-bit assembler for the C64 that runs on an ARM processor, but at least you can under Intel.
[EDIT] There is a (ancient) RISC-based ACME assembler here: https://web.archive.org/web/20150520143 ... brod/acme/ Might be useful, might not.
Or, if you want to stay retro, but learn something a bit more useful, from 2003: http://arantxa.ii.uam.es/~gdrivera/sed/docs/ARMBook.pdf
Cheers.
"Your Google-fu is weak Grasshopper. It is not the answer that enlightens, but the research.”
scruss
Sat Nov 25, 2017 11:18 pm
There's also Relaunch64, but it's very Java-based, so may be slow on a Raspberry Pi.
I found this useful: Commodore 64 assembly coding on the command line. With VICE and acme installed, I got a C64 demo to compile directly to a d64 image and run quite nicely. Emacs' Assembler mode, though not 65xx specific, understands 6502 opcodes.
Sun Nov 26, 2017 8:55 am
The Commode C64 uses a version of the 6502 micro-processor.
A quick search for "6502 assembler" immediately finds you this page: http://6502.org/tools/asm/
There is a ton of 6502 assemblers and other tools there. Written in Python, Java, C. All sorts. I'm sure there is something in there you can use.
scruss
Wed Nov 29, 2017 2:20 pm
Nah, acme works very well.
Ancient? That's positively space-age! The source builds cleanly on Raspbian, and defaults to producing Commodore PRG binaries.
Considering most 8-bit development relies upon TASM, a program whose author gave up on it around 2001, and now reliably exists only in MS-DOS versions that kick out a shareware message with every build, Linux source for acme from the mid 2000s is wonderful.
Pfft. 6502 teaches you that you can still do useful things with very few registers and a very weedy stack: The 6502 40th Anniversary Computer Badge
Wed Nov 29, 2017 2:59 pm
Why not just write you C64 code in C++ like Jason Turner does?
A Simple Commodore 64 Game in C++17: https://www.youtube.com/watch?v=zBkNBP00wJE
That is a whole PONG game with sprites and all. Compiled down to 800 bytes or so from C++.
scruss
Thu Nov 30, 2017 1:00 am
Because Jason's code is far more difficult to follow than assembly language:
https://github.com/lefticus/presentatio ... /Final.cpp
Thu Nov 30, 2017 9:53 pm
Well, I was being a bit tongue in cheek about the C++ for the C64 thing.
As to which is more difficult to follow, I guess that depends on if you are more used to reading/writing C++ than 6502 assembler.
The point of Jason's exercise there is to show that all those that say "C++ is crap because it produces bloated and slow code" are wrong.
I think he did very well.
Now, the challenge is, are there any C64 assembler gurus out there that can create the same simple program in assembler using less bytes than C++ ?
paulslocum
Thu Nov 30, 2017 10:34 pm
I used DASM for all my 65xx projects, should be easy to build on RPi:
http://dasm-dillon.sourceforge.net/
scruss
Fri Dec 01, 2017 2:42 am
Yeah, he did, but without his x86 to 6502 magic translator, it's of no use to anyone else. Nice party trick.
Since it's C++ that has anything to prove, I'd rather see a compiler do this: https://www.youtube.com/watch?v=sWblpsLZ-O8
You've got 256 bytes: go!
I can't see it doing very well with the required self-modifying code.
Fri Dec 01, 2017 8:15 am
scruss,
...without his x86 to 6502 magic translator, it's of no use to anyone else.
Of course the magic translator is available as well. So we can all play if we want.
That's a nice party trick as well.
Ah, it's the famous Linus Åkesson. He did a brilliant demo for the Parallax Propeller MCU a while back: http://hd0.linusakesson.net/files/lft_t ... 20x576.mp4
Luckily self-modifying code is a feature they have not yet shoehorned into the monster that is C++.
spike77
Wed Jan 03, 2018 4:54 pm
Thanks for the answers and happy new year 2018 btw!
while crawling throught the repositories, i found two packages:
  • crasm-1.8-1
  • xa65-2.3.5-1
i guess, i will try them and see which one works better. due to there being no Gui or IDE for my purpose, i think i'll have to use the combination of Texteditor and VICE-Emulator for writing and testing the code.
Wed Jan 03, 2018 8:03 pm
IDE?
We did not have any IDE for writing 6502 and other 8 bit micro assembler back in the day.
You certainly don't need one today. Any editor will do.
Personally I would use vim and install the 6502 syntax highlighter for it: http://www.vim.org/scripts/script.php?script_id=1314
Or the latest greatest Microsoft Visual Studio Code wih the 6502 plug in :https://marketplace.visualstudio.com/it ... scode-dasm
scruss
Thu Jan 04, 2018 3:04 am
But it wasn't fun. Developing and debugging on 8-bit machines needed multiple disk drives, a printer and lots of pen and paper scratchpad work. It would be like developing on linux with only cat as an editor, cc1 as a compiler and a simple linker to make executables.
These new cross-development IDEs:
  • host the compiler/assembler on a faster machine
  • often allow the code to run in a real-time emulator, with optional breakpoints
  • sometimes add sprite and sound editors that integrate with the assembly files
Thu Jan 04, 2018 4:51 am
scruss,
But it wasn't fun.
Sure it was.
We were young, micro-processors were new and exciting, we had a lot to learn there.
Developing and debugging on 8-bit machines needed multiple disk drives,...
What disk drives? We had no disk drives. We had to build the computer first, CPU, RAM, ROMS etc all wired wrapped. Eventually we built a cassette tape storage system using a handful of TTL chips.
a printer...
No printer either.
..and lots of pen and paper scratchpad work.
Oh yeah, lots of that.
It would be like developing on linux with only cat as an editor,...
Strangely enough I have done that...
But you are right. I would not like to have to do all that again...
On the other hand I cross-compile and emulate/simulate all kind of things for all kind of targets and often don't use an IDE. All from the command line. Much quicker and easier than all that mousing around in an IDE.
Thu Jan 04, 2018 8:17 am
The worst thing was CUTS (computer users tape system) and relying on getting the recording volume level just right on the cassette recorder. You could lose so much when that audio tape was unreadable.
https://en.wikipedia.org/wiki/Kansas_City_standard
Microprocessor, Raspberry Pi & Arduino Hacker
Mainframe database troubleshooter
MQTT Evangelist
Twitter: @DougieLawson
2012-18: 1B*5, 2B*2, B+, A+, Z, ZW, 3B*3, 3B+
Please post ALL technical questions on the forum. Do not send private messages.
Thu Jan 04, 2018 9:27 am
Oh yeah. I guess we were lucky to have the luxury of having an oscilloscope available to check that what came back from the tape was in good condition. Actually, the scope was our only debugging aid until we got our debug monitor in the boot ROM working. You know, load, run, break points, read/write memory and all that.
jahboater
Thu Jan 04, 2018 9:41 am
IDE?
I didn't even have an assembler for the first Z80 stuff I wrote. Writing code is hex is not my idea of fun.
But with only 1KB of memory (8 * 2102 chips), you couldn't write much.
Thu Jan 04, 2018 10:32 am
Same here. Except we were using the 6809.
We did get an assembler, eventually. After spending half a year translating our pseudo code to assembler then manually assembling that into HEX for the PROM programmer. By the time the assembler turned up we hardly needed it, having memorized most of the opcodes.
jahboater
Thu Jan 04, 2018 10:58 am
The worst bit was that after most changes the offsets and relative addresses all needed to be re-calculated and changed too.
Thu Jan 04, 2018 8:19 pm
Ah, well, there was the thing. The Motorola 6809 had a PC relative addressing mode. That meant one could write position independent code. One could write whatever complex subroutine, full of jumps and loops internally, and then put it anywhere in memory and it would work. Without having to fix up all those jump addresses.
Perhaps the first micro-processor with that capability.
Still one of my favourite architectures.
Who is online
