pieterbollen
Arduino IDE does not recognize letter 'M' [solved]
Sun Aug 13, 2017 12:26 pm
I have problems with the Arduino IDE, not everything works well, the problem is that when a M than in the program screen appear an W.
I tried also an older version off the IDE, with no result.
In all other programs i can type M and on on the screen it gives a M.
Only in the Arduino IDE M show W the character in the program is also wrong.
With copy/paste give the same problem.
Hope someone can help me
scruss
Re: Arduino IDE not recognize M
Sun Aug 13, 2017 3:18 pm
Just tried it with both versions 1.8.2 and 1.8.3, and unfortunately I can't reproduce the issue. Maybe your keymap is not set correctly for your country in raspi-config?
The way I installed 1.8.3 was:
mkdir -p ~/Applications
cd ~/Applications
wget https://downloads.arduino.cc/arduino-1.8.3-linuxarm.tar.xz
tar xvJf arduino-1.8.3-linuxarm.tar.xz
cd arduino-1.8.3
./install.sh
cd ..
rm arduino-1.8.3-linuxarm.tar.xz
This puts an icon on the desktop that you can start the Arduino IDE from.
pieterbollen
Sun Aug 13, 2017 3:39 pm
Hi scruss,
Thanks for your quick reply, i install the program followed your description but with no result.
The keyboard mapping must ok, in other programs there is no problem.
The problem is that i get a W when i type a M using the arduino IDE ????
Hope you have some more suggestions for me.
Regards Pieter
pieterbollen
Sun Aug 13, 2017 4:46 pm
Hi scruss,
I have changed the keyboard mapping (in the menu) it gives no result, now i installed it on another PI and it works OK now ?!?!
I think making a copy and start again.
regards Pieter
pieterbollen
Mon Aug 14, 2017 8:53 am
Problem solved ! :)
scruss
Mon Aug 14, 2017 3:31 pm
What was wrong?
pieterbollen
Mon Aug 14, 2017 4:47 pm
Hi scruss,
I realy don't know what was wrong i made a copy off the sd card from a working Raspberry and start again.
Thank you very much of your help.
I installed the arduino IDE in the way you described but now I have also an Icon on the desktop, how can i delete or remove it if necessary.
again thank you for you help.
regards Pieter
Eersel
Netherlands
scruss
Re: Arduino IDE does not recognize letter 'M' [solved]
Tue Aug 15, 2017 2:10 am
Just select and delete the icon. It won't delete your installation.
Who is online
Users browsing this forum: asandford and 3 guests
