newuser3000
can videos be played from a usb stick?
Tue Jan 29, 2013 9:24 pm
can I play an mp4 file from a usb stick on my pi? I have heard talk of something called 'omxplayer' but being a linux/RPi noob I have no idea how to use this or if it it's even what I'm looking for
any advice?
dextrus
Re: can videos be played from a usb stick?
Tue Jan 29, 2013 10:19 pm
Yes you can.
What OS are you using? Is it Raspbian? You might want to consider trying XBMC on the PI which is designed to playback audio and video files and is really easy to use.
There are three variants that I know of: Raspbmc, Xbian and OpenELEC.
Have more FUN with your Pi. Visit www.pi-fun.com
KenT
Wed Jan 30, 2013 8:14 am
If you plug in the usb stick you will see an entry appear on the left hand panel of the Filemanager.
Click on this entry and find the directory containing the file you want to play
open a terminal window in this directory >tools>open terminal window
type omxplayer -o hdmi filename or omxplayer -o local filename for analogue out
Pi Presents - A toolkit to produce multi-media interactive display applications for museums, visitor centres, and more
Download from http://pipresents.wordpress.com
newuser3000
Wed Jan 30, 2013 4:27 pm
when i put in 'omxplayer -o local (file name)' i get:
have a nice day ;)
whatdo i do here?
KenT
Thu Jan 31, 2013 9:21 am
try 128 MB RAM, use sudo raspi-config
look in omxplayer.log using leafpad. The file should be in the directory that you ran omxplayer from
post the command you typed here.
PS1981
Thu Jan 31, 2013 9:44 am
If you just get told "Have a nice day" then the video is either finished or it didn't work. I had a problem playing from my stick, then I realised that the name of the stick, and hence the command to play for example " omxplayer stick/videos/myvideo.mp4" had a space in it (was "store n go" or something). I renamed the stick "STICK" and now it works.
topguy
Thu Jan 31, 2013 9:50 am
File-names with space in them can be used if you:
- use " around the whole name: "/media/store n go/movie.mp4"
- or use \ in front of spaces: /media/store\ n\ go/movie.mp4
( the \ character is called "escape" and has to be used if filename contains strange characters. ( space ! $ \ ) )
