dan_in_sd
GLX optimizations?
Sun Dec 28, 2014 11:33 pm
hello,
Not sure if this is the place for this, but i installed the Raspian 'wheezy' image 2014-12-22 and then installed mesa utilitiiies with sudo apt-get install mesa-utils
Performance of glxgears command shows just 20 fps as seen here :( . while 'top' shows 56% CPU utilization for glxgears
94 frames in 5.0 seconds = 18.744 FPS
95 frames in 5.0 seconds = 18.850 FPS
95 frames in 5.0 seconds = 18.928 FPS
97 frames in 5.0 seconds = 19.362 FPS
Q: Is there something that can be done to improve GLX performance?
H/W info: R-pi model B+ , overclocked to 1.0Ghz,
UPDATE: I ran rpi-update. It did not help
Output from glxgears -info:
[email protected] ~ $ glxgears -info
GL_RENDERER   = Software Rasterizer
GL_VERSION    = 2.1 Mesa 8.0.5
GL_VENDOR     = Mesa Project
GL_EXTENSIONS = GL_ARB_multisample GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_copy_texture .................snip....
Output from glxinfo:
[email protected] ~ $ glxinfo
name of display: :0.0
display: :0  screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.4
server glx extensions:
    GLX_ARB_multisample, GLX_EXT_visual_info, GLX_EXT_visual_rating,
    GLX_EXT_import_context, GLX_EXT_texture_from_pixmap, GLX_OML_swap_method,
    GLX_SGI_make_current_read, GLX_SGIS_multisample, GLX_SGIX_fbconfig,
    GLX_SGIX_pbuffer, GLX_MESA_copy_sub_buffer, GLX_INTEL_swap_event
client glx vendor string: Mesa Project and SGI
client glx version string: 1.4
client glx extensions:
    GLX_ARB_create_context, GLX_ARB_create_context_profile,
    GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_import_context,
    GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_EXT_framebuffer_sRGB,
    GLX_EXT_create_context_es2_profile, GLX_MESA_copy_sub_buffer,
    GLX_MESA_multithread_makecurrent, GLX_MESA_swap_control,
    GLX_OML_swap_method, GLX_OML_sync_control, GLX_SGI_make_current_read,
    GLX_SGI_swap_control, GLX_SGI_video_sync, GLX_SGIS_multisample,
    GLX_SGIX_fbconfig, GLX_SGIX_pbuffer, GLX_SGIX_visual_select_group,
    GLX_EXT_texture_from_pixmap, GLX_INTEL_swap_event
GLX version: 1.4
GLX extensions:
    GLX_MESA_multithread_makecurrent, GLX_OML_swap_method,
    GLX_SGIX_pbuffer, GLX_EXT_texture_from_pixmap
OpenGL vendor string: Mesa Project
OpenGL renderer string: Software Rasterizer
OpenGL version string: 2.1 Mesa 8.0.5
OpenGL shading language version string: 1.20
OpenGL extensions:
    GL_ARB_multisample, GL_EXT_abgr, GL_EXT_bgra, GL_EXT_blend_color,
    GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_copy_texture,
    GL_EXT_polygon_offset, GL_EXT_subtexture, GL_EXT_texture_object,
    GL_EXT_vertex_array, GL_EXT_compiled_vertex_array, GL_EXT_texture,
    GL_EXT_texture3D, GL_IBM_rasterpos_clip, GL_ARB_point_parameters,
    GL_EXT_draw_range_elements, GL_EXT_packed_pixels, GL_EXT_point_parameters,
    GL_EXT_rescale_normal, GL_EXT_separate_specular_color,
    GL_EXT_texture_edge_clamp, GL_SGIS_generate_mipmap,
    GL_SGIS_texture_border_clamp, GL_SGIS_texture_edge_clamp,
    GL_SGIS_texture_lod, GL_ARB_multitexture, GL_IBM_multimode_draw_arrays,
    GL_IBM_texture_mirrored_repeat, GL_3DFX_texture_compression_FXT1,
    GL_ARB_texture_cube_map, GL_ARB_texture_env_add, GL_ARB_transpose_matrix,
    GL_EXT_blend_func_separate, GL_EXT_fog_coord, GL_EXT_multi_draw_arrays,
    GL_EXT_secondary_color, GL_EXT_texture_env_add,
    GL_EXT_texture_filter_anisotropic, GL_EXT_texture_lod_bias,
    GL_INGR_blend_func_separate, GL_MESA_resize_buffers, GL_NV_blend_square,
    GL_NV_light_max_exponent, GL_NV_texgen_reflection,
    GL_NV_texture_env_combine4, GL_SUN_multi_draw_arrays,
    GL_ARB_texture_border_clamp, GL_ARB_texture_compression,
    GL_EXT_framebuffer_object, GL_EXT_texture_env_combine,
    GL_EXT_texture_env_dot3, GL_MESA_window_pos, GL_NV_packed_depth_stencil,
    GL_NV_texture_rectangle, GL_NV_vertex_program, GL_ARB_depth_texture,
    GL_ARB_occlusion_query, GL_ARB_shadow, GL_ARB_shadow_ambient,
    GL_ARB_texture_env_combine, GL_ARB_texture_env_crossbar,
    GL_ARB_texture_env_dot3, GL_ARB_texture_mirrored_repeat,
    GL_ARB_window_pos, GL_ATI_envmap_bumpmap, GL_ATI_fragment_shader,
    ....snip...
RPI #1: Model B | Over-clocked | XBMC | RPI #2: Model B+ 512MB | Beautiful metal case from Lukse.LT | RPI #3: PI2 with Camera, 64GB USB Flash and Wi-Fi
MaxK1
Re: GLX optimizations?
Mon Dec 29, 2014 7:26 am
Overclock some more... ;-)
And stop watching "Reefer Madness"
You are in a maze of twisty little passages, all alike.
When General Failure and Major Disaster get together, Private Parts usually suffers.
PeterO
Mon Dec 29, 2014 8:41 am
AFAIK OpenGL is software rendered. If you want faster performance currently you need to switch to OpenGL-ES (until the OpenGL gpu integration is done).
PeterO
mimi123
Mon Dec 29, 2014 8:45 am
dan_in_sd wrote:hello,
GLX version: 1.4
GLX extensions:
OpenGL extensions:
    ....snip...
anholt.livejournal.com
Try the HARDWARE driver. The software one is useless.
Mon Dec 29, 2014 9:42 am
The SW driver clearly isn't 'useless'
It works exactly as expected.
But to the OP, the glxgears stuff uses software rendering because it's in OpenGL, but the GPU on the Pi uses OpenGL ES. If you modified the glxgears stuff to use ES, you would get 100's of frames per second.
mimi123
Mon Dec 29, 2014 9:44 am
jamesh wrote:The SW driver clearly isn't 'useless'
But is too slow, ...
Mon Dec 29, 2014 9:47 am
For what?
When I was learning 3D we were lucky to get a frame rendered every half an hour....
ghans
Mon Dec 29, 2014 10:47 am
If you're particularly bored , you can try this OpenGL to OpenGL
ES translator.
http://www.raspberrypi.org/forums/viewt ... 78&t=63264
It might or might not be what you are looking for.
ghans
mimi123
Mon Dec 29, 2014 12:58 pm
ghans wrote:If you're particularly bored , you can try this OpenGL to OpenGL
ES translator.
ghans
OpenGL 1.x only...
JeffD
Mon Jan 26, 2015 4:50 am
There is an old thread that shows glxgears converted to gles 1.x and 2.0 for the Rpi.
http://www.raspberrypi.org/forums/viewtopic.php?t=50418
Return to “Advanced users”
