PhilE
Re: New device tree kernel is in testing
Sat Jan 24, 2015 4:06 am
@DirkS Well done, you are correct on all counts.
@DougieLawson Please read up a bit before posting more misinformation. Not only is the syntax correct, it is not a good idea to enable options that you don't need. Besides, Tinue has already got it working - see the Update?
Sat Jan 24, 2015 3:53 pm
PhilE wrote:Please read up a bit before posting more misinformation. Not only is the syntax correct, it is not a good idea to enable options that you don't need. Besides, Tinue has already got it working - see the Update?
There's too much detail missing from the official docs and nobody has responded to my Github issue
https://github.com/raspberrypi/documentation/issues/150
Basically the RPF documentation is not fit for purpose at the moment.
This is a doctor free zone.
funtomas
Sat Jan 24, 2015 9:09 pm
what version of firmware / kernel will be officialy in jessie?
3.16 ???
Sat Jan 24, 2015 10:57 pm
funtomas wrote:what version of firmware / kernel will be officialy in jessie?
3.16 ???
I'd guess 3.18, since that's due to arrive in Wheezy when the RPF have ironed out the DT stuff.
n7wlc
Wed Jan 28, 2015 12:17 am
I've also found a problem with the SPI interface. I'm using the PiFace board, With the new kernel (and enabling SPI in config.txt), I get an error during the write to the SPI interface.
This does not work under the rpi-config kernel: 9ae54e3eb780309baf770a10c4e467ddcb011ef8
But it does work under the older (pre DT) kernel: f74b92120e0d469fc5c2dc85b2b5718d877e1cbb
In the new kernel, the /dev/spidev0.0 and .1 files are present. The C code that opens and initializes the port (via ioctl() calls) completes without complaint. But at the first write, I get an error (write via an ioctl call).
I was using the wiringPi library to talk to the PiFace and observed the same error.
I'd be glad to share code or do remote testing if that is helpful.
Sincerely,
Mike
PhilE
Wed Jan 28, 2015 8:44 am
Have you tried adding:
dtparam=spi=on
to your config.txt ?
As an aside, it is likely that these optional interfaces will be enabled by default in a future release, and raspi-config will be able to manipulate these DT settings.
n7wlc
Thu Jan 29, 2015 11:11 pm
It was turned on. I found the answer in a different post (http://www.raspberrypi.org/forums/viewt ... 65#p680665) where the spi_ioc_transfer structure was not completely initialized. Adding the suggested memset(&spi, 0, sizeof(spi)) did the trick.
Mike
Fri Jan 30, 2015 12:26 am
I've written patch and opened a Github issue for the broken piface/libmcp23s17 stuff.
https://github.com/piface/libmcp23s17/issues/8
mmi
Fri Jan 30, 2015 2:27 pm
My onewire temperature sensor (DS18B20) always reports 85 degrees if device tree is used.
I have uncommented w1 in config.txt (2 lines) and i use the latest firmware (dated Jan-28) and kernel 3.18.4. The w1 modules are loaded and when i do
cat /sys/bus/w1/devices/w1_bus_master1/28-000002db4902/w1_slave
it's normal behaviour: it replies the two lines with crc and temperature, but it's always 85°.
I have the 'old' RPi Model B Rev. 2 (without +).
If i switch off the device tree ('device_tree=' in config .txt) it works fine !
Any ideas?
Thanks and regards, mmi
Fri Jan 30, 2015 6:10 pm
Which w1 options in config.txt did you activate?
As I understand it you should have only one, either "dtoverlay=w1-gpio" or "dtoverlay=w1-gpio-pullup" depending if you need a pull-up pin or not.
mmi
Fri Jan 30, 2015 9:00 pm
In config.txt i activated
device_tree_overlay=w1-gpio
device_tree_param=gpiopin=4
and nothing else.
Additionally i have in modprobe.conf
options w1_gpio gpiopin=4 pullup=1
and no extra params for w1_therm.
But disabling 'pullup=1' is not a solution, it shows 85° then with and without devicetree.
Although i connected the sensor in its simplest way with 3 wires and a 4k resistor.
EDIT:
Although the sensor has worked without DT since over a year, it's getting weird for me now:
- principially i don't need an extra gpio pin in addition to gpio 4 where the sensors data line is connected
- setting 'pullup=1' as an option for w1_gpio configures gpio pin1 (which isn't a known gpio) for a extern pullup - is it right?
I ask myself why the sensor returns valid values (without DT) only with 'options w1_gpio pullup=1' although at gpio1 i didn't connect anything. Until now my misunderstanding was this would set the internal pullup on pin 4 in my case but that seems to be wrong.
I think best is to take a second sensor and try it on another RPi. I will report, so far sorry for the inconvenience.
ame
Sat Jan 31, 2015 8:10 am
mmi wrote:In config.txt i activated
and nothing else.
EDIT:
Before device tree I also have a parameter for w1_therm, in /etc/modules:
w1-therm strong_pullup=1
I haven't tried the new firmware again recently. I had it working by turning device tree off, but then I had to reformat, which put me back to the old version, and I didn't run rpi-update again.
I have four temperature sensors running in parasitic mode. All good, but I want to run a DS2406 sensor, so I need the later firmware which includes new modules.
peepo
Sat Jan 31, 2015 1:21 pm
PhilE
not clear to me this is exactly the problem I now need to understand, but LogiPi instructions do not seem to mention any issues around spi or spidev, yet I cannot currently seem to use....
so how do I load if hashing raspi-blacklist.conf and modprobe are no longer the way to go?
apologies if I'm confused, it comes naturally...
thanks again
Jonathan
PhilE
Sat Jan 31, 2015 1:27 pm
@ame and @mmi - There is a problem with the w1-gpio driver and its device tree implementation. We have accepted a non-upstreamed patch in order to support the parasitic power feature (I presume you are just using two wires, not the usual three), but it doesn't work as intended in device tree mode. If this device is important to you then I suggest you disable DT for now, but I assure you that we will get it working soon.
PhilE
Sat Jan 31, 2015 1:35 pm
@peepo: Do /dev/spidev* exist? If not, you probably haven't enabled the SPI interfaces. The next raspi-config release will be able to do this for you, but until then you will need to add "dtparam=spi=on" to /boot/config.txt and reboot.
It is also possible that you are using a library that hasn't been updated to work with the latest driver. See n7wlc's post above. Do you see any error messages?
peepo
Sat Jan 31, 2015 1:40 pm
Phil,
tx that makes much more sense, the first post felt like flannel...
had been looking for the rpi-update post (i2c), but Google found this first...
not the one, but:
http://raspberrypi.stackexchange.com/qu ... -no-such-f
should be there xxxx
wfm
ame
Sat Jan 31, 2015 8:04 pm
PhilE wrote:@ame and @mmi - There is a problem with the w1-gpio driver and its device tree implementation. We have accepted a non-upstreamed patch in order to support the parasitic power feature (I presume you are just using two wires, not the usual three), but it doesn't work as intended in device tree mode. If this device is important to you then I suggest you disable DT for now, but I assure you that we will get it working soon.
Thank you. My temperature sensors are indeed wired for parasitic power, and they are working. My DS2406 is parasitic-only and is visible on the bus (but no driver yet until I run rpi-update).
I'll run rpi-update later and disable device tree, then I'll load the drivers the conventional way.
Thanks.
sbp
Sat Jan 31, 2015 9:01 pm
Hi Phil
Can there be a problem with initramfs and the new device tree?
The reason for my question is that we have been trying to build piCore on the new 3.18.5 with DT - however we are not able to get it to boot from RAM.
We have had no problems with building before the new DT.
Cmdline
dwc_otg.fiq_fsm_mask=0x7 bcm2708.vc_i2c_override=1 smsc95xx.turbo_mode=N dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 initrd=0xa00000,4175913 root=/dev/ram0 elevator=deadline rootwait nortc loglevel=3 cron
config
# kernel image
kernel=zImage.img
# Specify initramfs
ramfsfile=pCP3185m.gz
ramfsaddr=0x00a00000
#device_tree=
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
#disable_overscan=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
arm_freq=800
core_freq=250
sdram_freq=400
force_turbo=1
# for more options see http://elinux.org/RPi_config.txt
hdmi_force_mode=1
But it result in kernel panic:
Kernel panic - Not syncing: VFC: Unable to mount root fs on unknown-block(1,0)
piCore is found here http://forum.tinycorelinux.net/index.ph ... ,57.0.html
piCorePlayer webpage: https://sites.google.com/site/picoreplayer/home
PhilE
Sat Jan 31, 2015 9:23 pm
I've had reports of it working. Does it boot if you disable device tree? Can you post extracts from the boot log in both cases?
mmi
Sun Feb 01, 2015 2:59 am
Thanks Phil and ame, but mine is not parasitic powered. I use the simple 3 wire connection and i thought it works with the current dt version.
By the way, in 'config.txt' for parasitic and normal powered sensors the same overlay is called. Who should ever call 'w1-gpio-pullup' ?
I think this has to be changed for parasitic powered sensors only from
to
device_tree_overlay=w1-gpio-pullup
Am i wrong or is it only for a while due to the bug you wrote above?
ktb
Sun Feb 01, 2015 4:52 am
sbp wrote:Hi Phil
http://www.raspberrypi.org/forums/viewt ... 29#p667529
It hasn't worked for me since then ^.
ShiftPlusOne
Sun Feb 01, 2015 5:14 am
The folks saying initramfs doesn't work... what does vcgencmd version say?
There's a fix for an initramfs-related issue in this commit: https://github.com/Hexxeh/rpi-firmware/ ... 026a25ff37
Is the firmware you're running before or after that commit?
ktb
Sun Feb 01, 2015 5:24 am
ShiftPlusOne wrote:The folks saying initramfs doesn't work... what does vcgencmd version say?
I believe the problem first showed up for me after running an update for 3.18.1+.
I'm currently running 3.18.3. I'll try out 3.18.4 or 3.18.4+. I might not have a chance to do that until tomorrow.
carriba
Contact: ICQ
Mon Feb 02, 2015 8:32 am
With this kernel release I do not longer see the I2C adapter files under the directory /sys/class/i2c-adapter :(
This is also the case with previous releases up to kernel release 3.12.36+. This is the latest release where I have back the I2C adapter files visible again as /sys/class/i2c-adapter/i2c-1.
PhilE
Mon Feb 02, 2015 10:02 am
This question has been answered in this thread, this thread, and several others. But the short answer is that you need to add:
dtparam=i2c=on
to /boot/config.txt.
Return to “Advanced users”
