Andrey V
Right way to compile libx264
Sun Jun 24, 2012 9:08 am
Hello!
I'm trying to encode video from webcam on Debian Wheezy with ffmpeg. And it works fine with any video codec but libx264. When i use libx264 all i get is:
ffmpeg -y -f video4linux2 -s 320x240 -r 1 -i /dev/video0 -r 1 -vcodec libx264 -s 320x240 -b:v 50K -f mp4 /tmp/test.mp4
ffmpeg version git-2012-06-21-9e63c30 Copyright (c) 2000-2012 the FFmpeg developers
  built on Jun 24 2012 02:22:41 with gcc 4.6.3
  configuration: --enable-gpl --enable-libfaac --enable-libmp3lame --enable-libx264 --enable-nonfree --enable-version3 --enable-librtmp
  libavutil      51. 59.100 / 51. 59.100
  libavcodec     54. 29.100 / 54. 29.100
  libavformat    54. 10.100 / 54. 10.100
  libavdevice    54.  0.100 / 54.  0.100
  libavfilter     2. 82.100 /  2. 82.100
  libswscale      2.  1.100 /  2.  1.100
  libswresample   0. 15.100 /  0. 15.100
  libpostproc    52.  0.100 / 52.  0.100
[video4linux2,v4l2 @ 0x12a4510] The driver changed the time per frame from 1/1 to 1/5
[video4linux2,v4l2 @ 0x12a4510] Estimating duration from bitrate, this may be inaccurate
Input #0, video4linux2,v4l2, from '/dev/video0':
  Duration: N/A, start: 227240.304332, bitrate: 6144 kb/s
    Stream #0:0: Video: rawvideo (YUY2 / 0x32595559), yuyv422, 320x240, 6144 kb/s, 5 tbr, 1000k tbn, 5 tbc
[buffer @ 0x12aaf70] w:320 h:240 pixfmt:yuyv422 tb:1/1 fr:1/1 sar:0/1 sws_param:flags=2
[ffmpeg_buffersink @ 0x12a02c0] No opaque field provided
[buffer @ 0x12aaf70] TB:1.000000
[scale @ 0x12a08d0] w:320 h:240 fmt:yuyv422 sar:0/1 -> w:320 h:240 fmt:yuv422p sar:0/1 flags:0x4
Illegal instruction
(code above works perfectly on x86)
As i understand it happens beacuse of absense of NEON, so i tried to recompile
libx264 with --disable-asm then ffmpeg, but result is the same.
So appearently there missing something else. But what?
saintdev
Re: Right way to compile libx264
Mon Jun 25, 2012 7:04 am
I haven't tried compiling x264, but it should be fairly trivial without asm and with some extra cflags/ldflags.
For ffmpeg/libav I would suggest starting with what I have below and appending whatever extra switches you need after. The cflags/ldflags are optional, but should help performance in floating point code (most of what you want in libav is integer, so it probably won't help much).
./configure --arch=armv6zk --cpu=arm1176jzf-s --extra-cflags="-mfloat-abi=softfp -mfpu=vfp" --extra-ldflags="-mfloat-abi=softfp -mfpu=vfp"
For x264 I would try starting with something like the following (I have not tested this, so ymmv). The float-abi and fpu options are mostly useless here, there is even less floating point math than libav, but it shouldn't hurt.
./configure --disable-asm --extra-cflags="-mcpu=armv6zk -march=arm1176jzf-s -marm -mfloat-abi=softfp -mfpu=vfp" --extra-ldflags="-mcpu=armv6zk -march=arm1176jzf-s -marm -mfloat-abi=softfp -mfpu=vfp"
NOTE: I have run FATE (libav's automated testing suite) and there are quite a few failures (largest being most of the VP8 tests fail).
SELECT `signature` FROM `users` WHERE `username`='saintdev';
Empty set (0.00 sec)
AndrewS
Mon Jun 25, 2012 1:00 pm
saintdev wrote:The cflags/ldflags are optional, but should help performance in floating point code (most of what you want in libav is integer, so it probably won't help much).
Or you could use Rasbian which allows you to make use of hardfloat :)
Andrey V
Tue Jun 26, 2012 12:36 pm
Thank you for advices!
I'll post back with right config when i get positive results.
Andrey V
Wed Jun 27, 2012 3:43 pm
After numerous fails and hours of waiting (2-4 hours per build) i decided to follow the advice of AndrewS and switched to raspbian, installed there libx264-dev and build ffmpeg without any optimisation. And it works!
Too bad i didn't found good way to build it on pure debian but it doesn't matter since there is better Raspbian with other optimisations.
AndrewS
Thu Jun 28, 2012 1:39 am
IMHO Raspbian is no less "pure Debian" than any of the other Pi-Debian-distros. Only difference is that the repository isn't stored on debian.org
tekmanro
Tue Jul 17, 2012 9:58 pm
I was wondering if you got this working, what are the perf characteristics of the software x264 encode? How far can you go in terms of resolution / fps? I suspect full 1080p/30fps is out of the question on 700Mhz, but what about 720p?
Thanks!
AndrewS
Wed Jul 18, 2012 12:18 am
I haven't tried it myself, but I can't see any reason why you couldn't software encode 1080p/30? It'll just be very slow...
Apparently when the camera add-on gets released, that'll somehow "unlock" the hardware x264 encoder, which is fast enough to do real-time FullHD.
tekmanro
Wed Jul 18, 2012 2:05 am
Hmm, I guess I should have rephrased that. What is the maximum resolution I can use to real-time encode a video stream from a web camera?
I assume software only, since the hardware encoder is not currently enabled due to licensing issues.
AndrewS
Wed Jul 18, 2012 11:28 am
Well, that's a very different question ;)
Given the limited CPU on the RPi, I suspect for any real-time software video encoding you'll have to choose a less compressed format than x264. I've seen several posts mentioning MJPEG?
khisraw
Mon Dec 02, 2013 2:48 am
Can I ask guys if ffmpeg or libav development packages are pre installed on the RPi or you need to install them?
Return to “Advanced users”
