unclejed613
running a script after a power failure....
Mon Sep 29, 2014 2:07 am
i've been trying to figure out debian's use of scripts during boot... i have a script i want run as user "pi" (uid 1000)... let's just call the script "foo"...
i have the following line entered in /etc/rc.local (this seems to work in other linux distro's but not in debian):
su- 1000 -c /home/pi/./foo
on the pi it doesn't seem to work.... what am i missing?
jojopi
Re: running a script after a power failure....
Mon Sep 29, 2014 3:38 am
unclejed613 wrote:su- 1000 -c /home/pi/./foo
Huh? "su-" is not a command. su does not accept numeric uids—you must specify "pi" rather than "1000". The "/./" in the command path is redundant.
Joe Schmoe
Mon Sep 29, 2014 6:39 am
But maybe the (non-standard) "su-" command does…
Maybe "su-" is something the poster wrote himself.
Also, not *all* of the "/./" is superfluous. You need at least one slash, or else it would be "pifoo".
Richdotward
Mon Sep 29, 2014 9:24 pm
I use crontab to run a script at boot.
Sudo crobtab -e
Just add
@reboot /home/.......... /....sh
Rich
Return to “Advanced users”
