first, I'm sorry if my question is not in the right place, I'm not sure about it..
I'm using a RPi model B / Rev1 with official RPi camera and TP-LINK WN725N USB WiFi adapter directly connected to the Pi.
I'm using an external battery which gives 1A or 2.1A. Actually I'm using 1A (but if you tell me that's better to use the 2.1A, I can).
It is running GStreamer to stream the camera (to give you an idea about the network use).
The problem is that the Pi crashes randomly.. It looks like it's the WiFi USB because its light disappear.
I read some network related problems in the wiki, apply the fixes but it continues..
I also read that could be the polyfuse ?
If I'm using a newer Pi (512MB one) could it solve the problem ?
Or should I really buy a powered usb hub ?
Best regards!
