istage
how to detect a new joining device by PI?
Wed May 28, 2014 11:12 am
hi, i want to use pi for detecting new joined device ip or more info. as host name, but i have not idea how to do that? need a help.
thanks
broo0ose
Re: how to detect a new joining device by PI?
Wed May 28, 2014 9:32 pm
Are you in control of the network? You could turn off your current dhcp server and run a dhcp server from the Pi. Then you will know when a new device connects to the network.
Otherwise you would need cooperation with another device.
Or maybe a periodic ping sweep of the network.
cyrano
Wed May 28, 2014 11:38 pm
Ping broadcast ip (x.x.x.255). Parse output.
Some devices might not respond to ping. There is no way to handle devices that want to hide from you...
Thu May 29, 2014 7:58 am
cyrano wrote:Ping broadcast ip (x.x.x.255). Parse output.
ping -b x.x.x.255
doesn't work on my network, only my ADSL router (x.x.x.1) and the wireless AP (x.x.x.251) reply all other machines (including my RPis) don't respond to that broadcast ping.
This is a doctor free zone.
mfa298
Thu May 29, 2014 10:47 am
You could have a look at arpwatch, from what I remember last time I used it (a long time ago) it would at least tell you mac address and IP of new machines and when they change.
bullwinkle
Thu May 29, 2014 7:06 pm
There is a similar question over here:
http://www.raspberrypi.org/forums/viewt ... 86#p557286
I've made some notes about how I monitor new devices connection to my network. It is still experimental, so you'll need to check things out for yourself. There is room for improvement.
http://dumb-looks-free.blogspot.fr/2014 ... vices.html
good luck
cyrano
Thu May 29, 2014 7:23 pm
ping -b x.x.x.255
Thx Dougie, I always forget Raspberry doesn't support it. Why is there still no support for multicast?
mfa298
Fri May 30, 2014 10:09 am
ping -b x.x.x.255
Pinging x.x.x.255 (more accurately the last IP in an IPv4 subnet) isn't multicast that's broadcast and it's likely to be down to whether the other devices are configured to respond to broadcast pings.
Multicast is a different technology (using special class D addresses) and I have used it to stream video from a pi camera to various other devices successfully. You could try pinging the all-computers multicast group 224.0.0.1 although my tests seem to suggest that not many clients respond to that either (tested both from a Pi and from a Linux machine)
lb
Fri May 30, 2014 12:12 pm
IPv6 multicast works much more reliably than IPv4 broadcasts. You can enable IPv6 on your Pi and execute "ping6 ff02::1%eth0", all IPv6-capable devices on the network should answer.
Another option is to listen for zeroconf/mdns packets, but that of course also needs to be supported by the devices.
davidevb6
Fri Jun 27, 2014 12:51 pm
Try this
import httplib, urllib
import subprocess
import time
import urllib
import urllib2
#205 digital probe
#208 monitor TFT  server web
#86 PC windows
#202 rele
#211 analog Probe
#212 analog Probe wireless
#206 door windows probe
#207 door windows probe wireless
ip_device_list = [205,208,86,202,212,207]
ip_device_list_Error = []
while True:
    for ping in ip_device_list:
        print ip_device_list
        print ip_device_list_Error
        if (ping in ip_device_list_Error) == False:
            address = "192.168.0." + str(ping)
            res = subprocess.call(['ping', '-c', '1', address])
            if res == 0:
                print "ping to", address, "OK "
            else:
                print "no response from", address
                ip_device_list_Error.append(ping)
        else:
            if res == 0:
                ip_device_list_Error.remove(ping)
            else:
                print "ping to", address, "failed!"
    time.sleep(300)
AndrewS
Mon Jun 30, 2014 12:15 am
That only looks for already-known IP addresses, but I guess the original question was about detecting new/unknown IP addresses.
davidevb6
Mon Jun 30, 2014 6:14 am
Good spot!
change this
into this
ip_device_list = range(1,255)   # 1,2,3....254
mfa298
Mon Jun 30, 2014 9:30 am
davidevb6 wrote:Try this
import subprocess
import time
import urllib
import urllib2
#205 digital probe
#86 PC windows
#202 rele
#211 analog Probe
while True:
            if res == 0:
            else:
        else:
            if res == 0:
            else:
    time.sleep(300)
This also relies on the device responding to ping requests (not everything will).
I would highly recommend looking at the arpwatch program I mentioned in an earlier post (sudo apt-get install arpwatch)
This monitors ARP packets (required for IPv4 networks to work) and will send an email with IP and MAC addresses for new devices it sees on a network (it may also include hostnames but It's been a while since I've use it).
Mon Jun 30, 2014 12:03 pm
mfa298 wrote: I would highly recommend looking at the arpwatch program I mentioned in an earlier post (sudo apt-get install arpwatch)
Interestingly arpwatch writes the arp data to /var/log/syslog (not /var/log/messages) on Raspbian, I thought it wasn't working.
Return to “Advanced users”
