ejfield
Mounting USB Memory
Wed Apr 30, 2014 7:17 am
It's possible I'm going mad, but I seem to be having odd things happening when I mount a USB memory stick. Typically, I plug the stick in, and look at it's device name with "df -h". This is USUALLY either "/dev/sda", or "/dev/sda1". I havn't worked out what the difference between them is, or why sometimes it's one and sometimes the other, but I thought it might have been something to do with the way it was formatted.
HOWEVER, yesterday, a stick which had happily been mounted via /etc/fstab as "/dev/sda /mnt/usb0........" seemed to suddenly decide that it's device name was now "/dev/sda1", and therefore the fstab mount failed!
Does anyone know what controls this behaviour, and how to stop it?
Ed
ghans
Re: Mounting USB Memory
Wed Apr 30, 2014 7:40 am
Tarcas
Wed Apr 30, 2014 2:08 pm
The difference between sda and sda1 is that sda is the drive, and sda1 is the first partition on that drive. sda2 will be the second partition and so on.
ejfield
Wed Apr 30, 2014 7:25 pm
ghans: I cant use UUIDs because I want to be able to mount different USB sticks at the same mount point.
Tarcas: Thanks for that clarification, but what determines which device name is used? Normally, I wouldn't have thought a USB stick, formatted at FAT32 I think, would contain any partitions, so I would have thought /dev/sda would be used. Why would it suddenly change to /dev/sda1?
Wed Apr 30, 2014 7:44 pm
Most USB sticks will contain at least one partition. That is standard practice. Some devices don't have a partition table and just use the whole device for the file system. This can give you an extra 0.5KB of storage, or more.
FTrevorGowen
Wed Apr 30, 2014 9:37 pm
ejfield wrote:ghans: I cant use UUIDs because I want to be able to mount different USB sticks at the same mount point.
Curiouser and curiouser ... why?
What happens if, when you format the sticks, you give them the same 'label', and use that? (And perhaps use the label as the "mount point name" too).
Trev.
ejfield
Thu May 01, 2014 10:04 am
Trev.
Well, I want to be able to plug in any USB stick containing my data, and expect to find it at the same mount point. Is this unreasonable? If I understand correctly, using UUID would not allow this, and using the 'label' seems an unnecessary restriction, though it might be a work around.
When I said earlier that I thought a USB memory stick wouldn't have any partitions, I meant of course that it would normally only have one, primary partition.
So I still dont understand why in one case, it appears as "/dev/sda", and in another as "/dev/sda1"..
ghans
Thu May 01, 2014 1:24 pm
Can't you assign several UUIDs on the same mountpoint ?
ghans
ejfield
Thu May 01, 2014 5:40 pm
ghans wrote:Can't you assign several UUIDs on the same mountpoint ?
ghans
Well I could, if I knew the UUID of every USB stick I'm ever likely to use. Unfortunately, I dont.
ghans
Sun May 04, 2014 2:47 pm
The "usbmount" tool uses udev internally , and allows to set
a fixed mountpoint for any stick it automounts.
ghans
Return to “Advanced users”
