Cross compile kernel: which gcc?
Posted: Wed Apr 23, 2014 6:38 pm
by audetto
I'm cross compiling the Pi kernel from a x86 machine.
On the https://github.com/raspberrypi/tools/tr ... rm-bcm2708
I can find 2 hard-float compilers
1) arm-bcm2708hardfp-linux-gnueabi
2) gcc-linaro-arm-linux-gnueabihf-raspbian
which are a 4.7 and 4.8 version respectively.
this page suggests to use the former http://elinux.org/RPi_Kernel_Compilatio ... from_Linux
(which btw works very well)
what is the difference? what do people normally use? what is the linaro used for?
Re: Cross compile kernel: which gcc?
Posted: Thu Apr 24, 2014 11:48 am
by SteveSpencer
What is used to build the releases available via the download links?
It sounds like the page at http://elinux.org/RPi_Kernel_Compilatio ... from_Linux needs revising or updating.
I've used both previously, but it would be better to know which one we should be using.
