RaTTuS
Auto start a script
Fri Jun 01, 2012 11:34 am
for Jessie | systemd see viewtopic.php?f=29&t=7192&p=828947#p828947
if you want to start a script off when your RPi boots up there are various ways but here is one that is very useful.
1) make sure your script runs [this is always useful ;) ]
2) edit /etc/inittab with your favourite root mode editor [I use sudo vi /etc/inittab YMMV]
2a) find the line
1:2345:respawn:/sbin/getty 115200 tty1
and replace it with
1:2345:respawn:/bin/login -f USERNAME tty1 </dev/tty1 >/dev/tty1 2>&1
where USERNAME is the name of your login user
...what this does is an autologin on tty1 [the 1st terminal]
then edit .bashrc on that user
and right at the end put something like :-
if [ $(tty) == /dev/tty1 ]; then
   ./script
fi
where script is the script you want to run.
so what happens is when the RPi is booted the 1st terminal will run your script - other terminals will want a login and if you login with your normal user will not auto run your script
if your script exits then you will be left at a command prompt, if you exit it will run again
Covfefe
grumpyoldgit
Re: Auto start a script
Fri Jun 01, 2012 11:41 am
Thanks for that; looks great. Just the sort of thing that people want to do. Candidate for Magpi3?
kernelcode
Sun Jun 03, 2012 11:43 am
I put stuff in /etc/rc.local if I want it to run on boot - it will run with root privileges (I think you could use sudo to stop that), and will run before login.
The advantage in my mind is that you aren't leaving a logged-in terminal (though maybe you could automatically log out with your method too?)
Joe Schmoe
Sun Jun 03, 2012 11:54 am
It's funny how that goes - one man's meat is another man's poison.
The *benefit* of doing it this way is that it runs visibly, meaning that you can see it running right there in the virtual console - and this is critical if it is interactive.
It is also true that when you put it into the /etc/rc* sequence, if it fails, it gums up your booting process (and this can be fatal). You have to be careful what you put there. Human frailty and all that...
kernelcode
Sun Jun 03, 2012 11:58 am
Joe Schmoe wrote: It is also true that when you put it into the /etc/rc* sequence, if it fails, it gums up your booting process (and this can be fatal). You have to be careful what you put there. Human frailty and all that...
I didn't know this - why is that and what kind of issues are we talking about?
RaTTuS
Fri Jun 08, 2012 9:45 am
rc.local is good for starting extra services
doing it this way will give you an output to the display [and is what I need] and also the ability to stop the script drop to a terminal and restart it with ease .
Covfefe
Joe Schmoe
Fri Jun 08, 2012 9:54 am
RaTTuS wrote:rc.local is good for starting extra services
You're getting it. Good show.
bredman
Fri Jun 08, 2012 10:02 am
These are two solutions for two very different things.
Add something to /etc/rc.local if you want it to execute every time the RPi is booted or rebooted.
Add something to ~/.bashrc if you want it to execute every time a specific user logs in.
On a RPi, you could argue that they are almost the same if there is likely to ever be only one user. It really depends on whether you want the command to be executed before or after the user enters his username/password.
@kernelcode
Putting something into /etc/rc.local adds it to the boot sequence. The word "sequence" is important, if your code gets stuck then the boot sequence cannot proceed. The same with ~/.bashrc, if you put a faulty command in here you may not be able to login.
Note that the RPi may have a file on the FAT partition named /boot/boot.rc which performs the same function as /etc/rc.local. This is safer because you can edit this partition from any computer.
paulsmithenator
Tue Mar 05, 2013 7:50 pm
What's the difference between .bash_profile and .bashrc?
SuperTaranta
Mon Mar 11, 2013 5:54 am
Curious if this would work for commands?
So for instance running quake on login.
would remove the ./script and place sudo /home/user/quake3/ioquake.arm?
Is there a way to make it run once? so like it runs, but when you quit it, it doesn't attempt to again?
As well as Curious about the answer to the post above me as well :D
RaTTuS
Mon Mar 11, 2013 9:00 am
paulsmithenator wrote:What's the difference between .bash_profile and .bashrc?
.bashrc is for non login shells and
.bash_profile is for login shells
so if you login then you .bashrc is run
if you open another terminal then .bash_profile is run
IIRC
man pages and google may help on this
SuperTaranta wrote:Curious if this would work for commands?
yes - though with sudo it will still ask for a password
if you do it how I described in the 1st post after the ./script has run then you will be left at the command prompt
if you then
exit
then it will re-log you and re-run ./script
Covfefe
SuperTaranta
Mon Mar 11, 2013 3:25 pm
IIRC
if you then
exit
Alright :), thanks for the reply man.
DetlevSchm
Tue Mar 12, 2013 10:27 am
RaTTuS wrote: .bashrc is for non login shells and
You swapped the file names, it should read:
So, if you login, then your .bash_profile is run.
If you open another terminal, then .bashrc is run.
No harm done 8-).
heldny
Wed May 01, 2013 3:55 pm
if i post my script at rc.local, the autoboot is ok.
the problem is that i use an audio library in the script.
os.system('mpg123 mysound.mp3 &')
the raspberry don't play mysound.mp3 with the autoboot. where i can put my script that the script goes on after the library is up?
RaTTuS
Wed May 01, 2013 4:01 pm
full paths to everything
Covfefe
heldny
Wed May 01, 2013 4:19 pm
in rc.local:
sudo python /home/pi/prog.py &
or where full path?
RaTTuS
Thu May 02, 2013 10:32 am
in rc.local
you do not need
sudo
as it is run as root anyway
but the
may need to point mysound.mp3 to the full path of that
Covfefe
TheITGuy
Wed Feb 12, 2014 3:08 am
RaTTuS wrote:if you want to start a script off when your RPi boots up there are various ways but here is one that is very useful.
1) make sure your script runs [this is always useful ;-p]
2)edit /etc/inittab with your favourite root mode editor [I use sudo vi /etc/inittab YMMV]
2a) find the line
and replace it with
where username is the name of your login user
./script
fi
Excellent Post!!
I've got a question hopefully someone can answer. I'm trying to set up a timelapse script to execute on bootup. I've finally got "raspiLapseCam.py" working, now I just need it to start upon boot up since this will be in an isolated location, plug & go setup.
This part states modifying the .bashrc,, and adding the following line.
./script
I just wanted to clarify the syntax before committing to this process.
I'm going to enter the following for this statement.
if [ $(tty) == /dev/tty1 ]; /usr/local/bin/raspiLapseCam.py
Is this correct???
Thanks for your time.
RaTTuS
Wed Feb 12, 2014 9:44 am
umm possibly I have to say I always
do
if [ ... ] ; then
command
fi
in bash scripts but IIRC the single line option is fine...
Covfefe
TheITGuy
Wed Feb 12, 2014 4:12 pm
RaTTuS wrote:umm possibly I have to say I always
do
if [ ... ] ; then
command
fi
So my syntax would be the following;
if [ $(tty) == /dev/tty1 ]; then /usr/local/bin/raspiLapseCam.py
fi
Have a good evening
Thanks RaTTuS
RaTTuS
Auto start a script systemd [Jessie]
Wed Oct 14, 2015 10:26 am
If you have a script that you want to run on boot up the it's pretty easy in Jessie via systemd
assuming that you have created your script correctly i.e.
the first line has the interpreter stated :-
#!//bin/sh
or python or perl or whatever full path please
and has the correct modes i.e.
chmod 755 scriptname
i.e.
nano Ping
#!/bin/sh
ping -c 50 www.google.com
chmod 755 Ping
./Ping #see that it works
now we create the service
sudo nano /lib/systemd/system/ping.service
[Unit]
Description=Ping auto test
[Service]
ExecStart=/home/pi/Ping
[Install]
WantedBy=multi-user.target
then you can see its status like
sudo systemctl status ping.service
enable it like
sudo systemctl enable ping.service
run it like
sudo systemctl start ping.service
you will not see anything on the screen this is to be expected
but if you
also you can see that it is running via
ps axOT
this script will run when you reboot the machine when it enters the multi-user part of the boot
for my next trick I'll start up a script on a spare virtual terminal that can accept input see
viewtopic.php?f=29&t=7192&start=25#p898424
Covfefe
Joe Schmoe
Wed Oct 14, 2015 3:32 pm
But that's the whole point. That's what we want to do - run it on a VC.
All the stuff before that - in your post - is just noise, because it is essentially doing it the 20th Century way.
I know this sounds harsh, but you have to be aware of how people read. Their attention span dwindles fast after the first few sentences. Most people won't even notice that the substantive part of your post is in the last sentence.
tadd
Re: Auto start a script systemd [Jessie]
Wed Oct 14, 2015 4:02 pm
RaTTuS wrote:then you can see its status like
enable it like
run it like
but if you
This works! Yeah. is there a concise and relevant text about the writing of a .service file that we can reference? I'm specifically interested in Raspberry PI JESSIE compatible operation. One feature I'm immediately looking for is the ability to respawn the executable if it quits.
Thanks for any help!
Tadd
RaTTuS
Wed Oct 14, 2015 4:06 pm
yeah the systemd tutorial stuff ;)
if you have
Restart=always
in the [Service] section then it will restart
the next one will be a bit more involving - as it has to do a lot more but I'm not in a position to post it right now as I have some win10 PC issues I'm dealing with.
Covfefe
tadd
Wed Oct 14, 2015 4:59 pm
RaTTuS wrote:yeah the systemd tutorial stuff ;)
Thanks.
I also found this document
https://wiki.archlinux.org/index.php/Systemd
Tadd
Return to “Advanced users”
