RESTful Web Service
Posted: Thu Feb 27, 2014 11:03 am
by 7ewis
I'm not entirely sure what I am looking for, but I need to be able to run the REST API on my Pi. I'll explain my current setup first.
I have a Raspberry Pi, that eventually is going to be able to communicate with Salesforce using REST, and when a High Priority Support Case comes in, the Pi will turn on a flashing light.
At the moment, I have the Pi connected into my network running Raspbian. It hosts a website using Lighttpd, with Python CGI enabled. So I have set it up so that I can use POST from the index page, specifiying a password to allow control, power on/off, a time period to stay on, and the device I want to control. So for example, I could go to:
cgi-bin/power.py?device=1&power=on&time=0&password=password
And that would turn on Device 1 indefinitely. (I don't think it's relevant, but the way that all works is via a Python wrapper, which allows me to send commands to a USB RF Transmitter, which is paired to 3 RF Sockets plugged into the wall).
So I have most of it working, it's just the connectivity with Salesforce I need to work out. But I have never used REST before, and don't really have much experience in programming anyway. My friend knows how to setup the Salesforce side, which I don't have direct access to, so I just need to get the REST API setup.
Does anyone here have any experience with it? Where should I start?
Re: RESTful Web Service
Posted: Thu Feb 27, 2014 12:35 pm
by topguy
I'm a little unsure what is client and what is server in your setup.
Are you going to "poll" Salesforce via REST to detect a state change ( High Priority Support Caes present or not) ?
(Then your friend has to specify the REST API so you can use it.)
Or is the Salesforce going to use REST to trigger the light automatically when a HPSC arrives ?
(In which case you have to specidy a REST interface for your friend to use.)
Both CherryPy and web.py are Python modules you can use to create simple RESTful interfaces. (you can probably skip the lighttp server)
Posted: Thu Feb 27, 2014 3:08 pm
by 7ewis
topguy wrote:I'm a little unsure what is client and what is server in your setup.
Sorry, Salesforce is going to trigger the light when a case comes in. So I believe I have to create some sort of REST service on the Pi?
What do they actually do? Because I do already have Lighttpd setup. Would it be easy to transition over?
Say I do use CherryPy, what actaully needs to be setup to allow Salesforce to connect to it using REST? From what i have reasearched, it looks like I need a small bit of code stating what it needs to return or something, which would just be a POST to power.py?power=on&device=1 or something?
Posted: Fri Feb 28, 2014 10:02 am
by topguy
A simple tutorial http://rest.elkstein.org/2008/02/what-is-rest.html can probably explain it better than me.
If your friend has integrated Salesforce with other REST interfaces before he should probably give you a guideline on how the API could look.
Posted: Wed Mar 26, 2014 10:49 am
by 7ewis
I have now installed Flask onto the Pi. And it accepts JSON, as I can see the requests it receives in the console.
Does anyone have any experience with Flask? I'm not too sure how I would parse requests, and forward them to my Python script to turn on/off the devices.
Posted: Wed Mar 26, 2014 2:17 pm
by iinnovations
REST is not a technology. It is not a language or a service. It is a philosophy. POST and GET are methods that fits within this framework philosophy.
Responding to post query requires nothing more than either a service listening specifically for it, or something basic like a web server than takes action. In apache, for example, you can set up a script alias in your site config that will process a URL from, say, cgi or wsgi. If you can use GET, you can display your passed parameters using javascript if you like. Anyhow, the point is that you don't need a fancy framework to do what you are trying to do. I'll link you an apache example when I get a second here. Your configuration will be different for your server obviously.
Posted: Wed Mar 26, 2014 3:15 pm
by iinnovations
Here is a sample wsgi script that retrieves POST parameters and processes in python. I call it using AJAX in a web page, but you can use it for direct POST calls if you like. It take a WSGIScriptAlias directive in the apache site configuration, with mod_wsgi enabled.
https://github.com/iinnovations/iicontr ... tions.wsgi
