kennydude
Animated GIF on Framebuffer
Sat Jan 04, 2014 8:01 pm
I was wondering if it's possible to play an animated gif (and loop it preferably) on the framebuffer?
The closest I have is being able to use mplayer, however it blanks the screen while it loops which makes the output look horrid.
Thanks,
Joe :)
P.S Apologies if this is posted in the wrong place
AndyD
Re: Animated GIF on Framebuffer
Sun Jan 05, 2014 7:28 am
With a quick search, unfortunately I couldn't find a solution. The popular framebuffer image viewer (feh and fbi) don't appear to support animated GIFs.
kennydude
Tue Jan 28, 2014 4:02 pm
I seem to have found a solution to this problem accidentally. (Qt)
So, QT doesn't actually need X or Wayland to run on Raspberry Pi, which is awesome! QT also supports GIFs out of the box!
What I did:
1. Installed QT binaries from http://twolife.be/raspbian/ (make sure you have qtquick1-qml-plugins installed!)
2. Made a test.qml file (assuming you have a gif file called load.gif):
    import QtQuick 2.0
     Rectangle {
        width:800
        height:600
	color:"#000"
    	AnimatedImage {
        	anchors.centerIn: parent
		source:"load.gif"
    		fillMode:Image.PreserveAspectCrop
3. qmlscene -platform eglfs test.qml
It seems to work :)
When I get everything coded up how I want, it'll land in my github: https://github.com/kennydude/SimpleMC
AndyD
Tue Jan 28, 2014 8:43 pm
Good idea!
towolf
Tue Jun 23, 2015 12:17 am
I want to try this, but my Rpi is running Arch.
Any idea which of these packages I need to install? I don’t want to clutter the Rpi too much and install everything
[email protected]:~# pacman -Ss qml
extra/calligra-gemini 2.9.5-2 (calligra)
    QML interface for Calligra Words and Stage
extra/kdeclarative 5.11.0-1 (kf5)
    Provides integration of QML and KDE Frameworks
extra/kdeplasma-applets-plasma-nm 0.9.3.6-1
    Plasma applet written in QML for managing network connections
extra/kdevelop-qmljs 1.7.0-1
    PHP language and documentation plugin for KDevelop
extra/plasma-nm 5.3.1-1 (plasma)
extra/qt5-declarative 5.4.2-1 (qt qt5)
    Classes for QML and JavaScript languages
extra/qt5-webchannel 5.4.2-1 (qt qt5)
    Provides access to QObject or QML objects from HTML clients for seamless integration of Qt applications with HTML/JavaScript clients
extra/qt5-webkit 5.4.2-1 (qt qt5)
    Classes for a WebKit2 based implementation and a new QML API
extra/sddm 0.11.0-1
    QML based X11 display manager
community/qmltermwidget 0.1.0-1
    QML port of qtermwidget
dividuum
Tue Jun 23, 2015 10:39 pm
You might also just convert your gif files to mp4 using ffmpeg and use (for example) omxplayer. That way you can use the hardware acceleration of the Pi.
info-beamer hosted - A user and programmer friendly digital signage platform for the Pi: https://info-beamer.com/hosted
towolf
Wed Jun 24, 2015 11:59 am
The problem is that the looping of omxplayer is not too solid. Earlier it didn’t work stably, and in more recent builds it trims off some seconds off the end. For seamless gifs this is not good.
ChIdea
Mon Apr 04, 2016 5:40 pm
Hi. I was able to play GIF onto FB with only Python3, mainly by fcntl and Pillow library which are all pre-installed in latest raspbian. You don't have to install Qt with this approach.
Here's the project link.
https://github.com/chidea/FBpyGIF
Return to “Advanced users”
