suipaste
issues running pi4j examples
Sun Dec 29, 2013 6:29 pm
I've got some issues running the java example files included in the tutorial below:
http://www.savagehomeautomation.com/piface
I'm trying to run the following command:
javac -classpath .:classes:/opt/pi4j/lib/'*' -d . PiFaceExample.java
but get this error when I execute it:
PiFaceExample.java:66: error: error while writing <anonymous PiFaceExample$1>: No space left on device
        piface.getSwitch(PiFaceSwitch.S1).addListener(new SwitchListener() {
1 error
I'm really new to linux and the Pi in general. Does this mean the whole SD card is out of space or something more specific. My googling lead me to the following command which checks available space:
$ df -k
this returns the following:
Filesystem     1K-blocks    Used Available Use% Mounted on
rootfs           1804128 1778780         0 100% /
/dev/root        1804128 1778780         0 100% /
devtmpfs          216132       0    216132   0% /dev
tmpfs              44880     236     44644   1% /run
tmpfs               5120       0      5120   0% /run/lock
tmpfs              89740       0     89740   0% /run/shm
/dev/mmcblk0p1     57288   18888     38400  33% /boot
tmpfs              89740       0     89740   0% /tmp
Not sure if there's any clues there as to why I can't run this example to get some flashing lights on my PiFace...
Re: issues running pi4j examples
Sun Dec 29, 2013 6:34 pm
What size SDcard is it?
Because
says you've used 1.8GB
Have you run raspi-config to expand the filesystem to use all the available space on the card?
Is /var/log full of crud and cruft?
Have you cleaned up the apt cache?
Have you looked at the installed software packages to get rid of things you've not used and never plan on using?
suipaste
Sun Dec 29, 2013 6:45 pm
It's a 4gb SD. Guess i need to expand the file system.
I've just found it all a bit hard to work out because I'm doing it all through SSH which I'm also new at.
And also Yes it will be full of crud I don't need. It's for a java project so I might get an image ready with everything on it I need minus the crud and back that up encase I brick it...
Cheers, I'll look into those things.
Update: Yep that sorted it!
Return to “Advanced users”
