thsBavR10
Re: Overclocking
Tue Oct 23, 2012 10:00 am
could you try
cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_cur_freq
immediately after
time echo "scale=2000;4*a(1)" | bc -l
better in one line:
time echo "scale=2000;4*a(1)" | bc -l && cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_cur_freq
The output from /proc/cpuinfo seems to be static.
trn
Re: Overclocking
Tue Oct 23, 2012 10:31 am
after
real 0m24.280s
user 0m23.610s
sys 0m0.030s
700000
thsBavR10
Re: Overclocking
Tue Oct 23, 2012 10:37 am
please check with
dmesg | grep cpufreq
if there is an line
e.g.
bcm2835-cpufreq: min=700000 max=800000 cur=800000
This is indicating, wether your parameters in config.txt have been accepted.
trn
Re: Overclocking
Tue Oct 23, 2012 10:39 am
[ 1.977888] bcm2835-cpufreq: min=700000 max=900000 cur=700000
[ 1.983792] bcm2835-cpufreq: switching to governor powersave
[ 1.996165] bcm2835-cpufreq: switching to governor powersave
trn
Re: Overclocking
Tue Oct 23, 2012 10:55 am
When cpu work on 900?
Why on 700 when i get him to work ?
thsBavR10
Re: Overclocking
Tue Oct 23, 2012 11:00 am
I'm missing lines with
 bcm2835-cpufreq: switching to governor ondemand
Seems that your config.txt settings are not in use.
I don't know why.
trn
Re: Overclocking
Tue Oct 23, 2012 11:14 am
thsBavR10 wrote:I'm missing lines with
I don't know why.
Anybody know?
thsBavR10
Re: Overclocking
Tue Oct 23, 2012 11:35 am
Please give
echo ondemand > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
a try.
(found it at http://www.raspberrypi.org/phpBB3/viewt ... nd#p188395).
"ondemand" should be the default value.
Edit found this:
Yes, we boot up with powersave governor and switch to ondemand with init script. "apt-get upgrade" should get you this bevaviour, but you can do it manually by adding:
echo “ondemand” > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
to /etc/rc.local.
http://www.raspberrypi.org/phpBB3/viewt ... or#p176976
trn
Re: Overclocking
Tue Oct 23, 2012 11:51 am
Thanx
now is ok
real 0m18.623s
user 0m18.390s
sys 0m0.040s
900000
jaromanda
Re: Overclocking
Tue Oct 23, 2012 12:09 pm
then try again :D
edit: too slow
I now own 2 RPi - does that mean I own a circumference?
Coxeroni
Re: Overclocking
Thu Oct 25, 2012 9:14 am
dom wrote:
Wanderlei wrote:Yes it only occurs only with overclocking, I try overclocking extremely mildly by 2 and first reboot it is corrupted. (the build of openelec used is actualy r192220)
gpu_mem=256
arm_freq=702
sdram_freq=402
gpu_freq=252
core_freq=252
Can you limit core_freq to 250. (gpu_freq has no effect). I think that is the setting that provokes corruption (for some boards).
You should be able to set arm_freq and sdram_freq much higher (and the arm_freq is the most important one).
Thanks for that remark. In my case, setting core to 333 MHz resolved my issue of Openelec freezing at high load. Now running
arm_freq=1000
sdram_freq=500
core_freq=333
over_voltage=6
butter smooth on my 512 MB pi with not lock-ups so far. Hope I don't get any corruption soon, this I will see with longer test runs.
dliloch
Re: Overclocking
Thu Oct 25, 2012 10:59 am
hello,
when I use vcgencmd get_config
I was expecting to see my current config ..
but all that came back was:
get_config [config|int|str]
does anyone know what the operands do?
and how do you list the config with vcgencmd?
thanks
gogiman
Re: Overclocking
Thu Oct 25, 2012 12:07 pm
seems you need to do it like this:
vcgencmd get_config config
vcgencmd get_config int
vcgencmd get_config str
dliloch
Re: Overclocking
Thu Oct 25, 2012 12:19 pm
[email protected] ~ $ vcgencmd get_config config
config is unknown
[email protected] ~ $ vcgencmd get_config int
arm_freq=1000
core_freq=500
sdram_freq=500
over_voltage=6
disable_overscan=1
boot_delay=1
temp_limit=85
[email protected] ~ $ vcgencmd get_config str
I guess int is for what it was initially.. then config is
for if you change while running?
str?? don't know
dom
Re: Overclocking
Thu Oct 25, 2012 12:59 pm
gogiman wrote:Hi,
vcgencmd get_config int - lists all the integer config options that are set (non-zero)
vcgencmd get_config str - lists all the string config options that are set (non-null)
vcgencmd get_config <config> - lists that specifc config value. E.g. vcgencmd get_config arm_freq
dliloch
Re: Overclocking
Thu Oct 25, 2012 1:15 pm
thanks for the clarification of the parms..
however.. I have gpu_freq=300 and it comes back as zero
and gpu_mem is unknown? I have it set to 64
I could see maybe the program does not do gpu stuff but it does recognize the gpu_freq parm but returns zero ..
-don isenstadt
dom
Re: Overclocking
Thu Oct 25, 2012 2:31 pm
dliloch wrote:thanks for the clarification of the parms..
-don isenstadt
gpu_mem is parsed by bootcode.bin, rather than start.elf, so start.elf knows nothing about it. I guess I could parse it from start.elf just to make get_config work...
gpu_freq worked for me:
vcgencmd get_config gpu_freq
gpu_freq=300
dliloch
Re: Overclocking
Thu Oct 25, 2012 6:14 pm
@346337 all is good re gpu_freq. I was using 345210 .. so now I will always begin my posts @......
I would also like to thank all of you @ the foundation the the great work that you have done with
this device.. and it's associated software ..
thanks so much.. the keys to the kingdom for $35! :-)
portets
Re: Overclocking
Fri Oct 26, 2012 12:53 am
dom wrote:Latest firmware now sets:
init_emmc_clock=100000000
and
sdhci-bcm2708.emmc_clock_freq=100000000
as I believe this helps the sdcard corruption problem when overclocking core_freq.
Although this got rid of my ext4 corruption on boot when overclocked and force_turbo=1(been using this firmware and later since), it may have caused corruption under high cpu/io load for me. Take my testing lightly though, as I've only done six test runs. Unless anyone else can confirm.
4/4 times that I've compiled pcsx-rearmed(ps1 emulator) for retroarch, it compiles to about 75% and then gcc spits out a long list of gibberish. It seems to appear when gcc runs out of ram and starts using swap space. I reboot to find my ext4 is completely corrupt. I then re-flashed this same exact disk image to my sd, with the only changes being:
init_emmc_clock=50000000
sdhci-bcm2708.emmc_clock_freq=50000000
2/2 times compiling pcsx-rearmed completed successfully.
If anyone wants to test, I was using gpu_mem=64 on a 256 pi, repository is here: https://github.com/libretro/pcsx_rearmed
./configure --platform=libretro
make
overclock was 1000/500/600(arm/core/sdram)
lmoss30
Re: Overclocking
Sun Oct 28, 2012 12:49 pm
Afternoon All,
I tried the settings that were posted on the elinix forums, so i reliase that was at own risk etc .. but since trying them i my first PI fails to boot it gets to a line that says.
[3.446958] smsc95xx 1-1.1.0: eth0: register 'smsc95xx' at usb-bcm2708_usb-1-1, smsc95xx USB 2.0 Ethernet, b8:27:eb:7e:64:8f
could any one shed some light on that might be going on. and any potentail fixes, i have tried clearing out the config.txt file so that it just have my hdmi settings on.
overclock settings were
arm_freq=1150
core_freq=500
sdram_freq=600
over_voltage=8
dom
Re: Overclocking
Sun Oct 28, 2012 12:59 pm
lmoss30 wrote:I tried the settings that were posted on the elinix forums, so i reliase that was at own risk etc .. but since trying them i my first PI fails to boot it gets to a line that says.
arm_freq=1150
core_freq=500
sdram_freq=600
over_voltage=8
Very few boards will run reliably with those settings (mine doesn't). If yours doesn't boot, then you'll have to reduce the settings and find the hightest settings that work for you.
Note: a high overclock also requires more power from the power supply. You may want to verify you are still getting 5V with those settings:
http://elinux.org/R-Pi_Troubleshooting# ... r_problems
lmoss30
Re: Overclocking
Sun Oct 28, 2012 8:03 pm
arm_freq=1150
core_freq=500
sdram_freq=600
over_voltage=8
Thanks for the response, i cleared out the config.txt file which i believed should reset the system to the standard 700Mhz setttings and i am still experiencing the same problems, power supply is ok at a stable 4.98v
is it possible to damage components by over clocking?
wallarug
Re: Overclocking
Sun Oct 28, 2012 9:16 pm
Yes, if you are overvolting you void your warrenty.
jaromanda
Re: Overclocking
Sun Oct 28, 2012 9:49 pm
I thought overvolting with force_turbo=0 does NOT void warranty
Dilligaf
Re: Overclocking
Sun Oct 28, 2012 11:16 pm
Only overvolt of 6 or less.
Return to “Advanced users”
