pukster
We need a cross compilation tutorial
Thu Nov 28, 2013 7:49 am
Before anyone lashes out at me, I did google this problem, I looked all over Stack Overflow and I spent about 15 minutes searching it in the forums here, but I have not found a suitable tutorial on how to cross compile a program for the raspi. I found great sites on which cross compilers to download, like this one
raspi tools
and how to set up a cross compiler, like this one
Installing Raspberry Pi Cross-Compiler
But then everyone is completely silent when it comes to what to do with the cross compiler once it's up and running. I think what would go a long way is if someone was kind enough to put up some sticky tutorial posts demonstrating the step by step process of installing, for example, omxplayer. Specifically, it should outline how to modify the conventional
./configure
make
sudo make install
commands such that they become aware of the cross compilation process.
MattF
Re: We need a cross compilation tutorial
Thu Nov 28, 2013 11:22 pm
A rough answer from my history:
rm -rf ~/311MOD && mkdir ~/311MOD && make -j2 ARCH=arm CROSS_COMPILE=${CCPREFIX} && make ARCH=arm CROSS_COMPILE=${CCPREFIX} INSTALL_MOD_PATH=/home/apf/311MOD modules_install && cp arch/arm/boot/zImage /home/apf/Jul4 && cd ~/311MOD && tar jcvf ../Jul4/Sep25.tar.bz2 .
echo $CCPREFIX /home/apf/PI/tools/arm-bcm2708/arm-bcm2708hardfp-linux-gnueabi/bin/arm-bcm2708hardfp-linux-gnueabi-
I know it's a little terse, but perhaps may point in the right direction
Oh yes, and menu config is
make ARCH=arm CROSS_COMPILE=${CCPREFIX} menuconfig
pukster
Fri Nov 29, 2013 12:43 am
Thank you, it is a step in the right direction
ShiftPlusOne
Fri Nov 29, 2013 2:37 am
Take a look at the cross linux from scratch arm sysroot tutorials.
http://cross-lfs.org/view/clfs-sysroot/arm/index.html
It will depend on the software, so run ./configure --help and read the output carefully.
In general, in terms of generic autotools packages, you do this:
./configure --build=${CLFS_HOST} --host=${CLFS_TARGET}
make
Where CLFS_HOST="$(echo $MACHTYPE | \
sed "s/$(echo $MACHTYPE | cut -d- -f2)/cross/")" and CLFS_TARGET coresponds to your target tuplet.
Up to you to figure out how you want to install it after it's compiled (you can use --prefix and install to the sd card).
I haven't looked at omxplayer recently, but it when I did, it wasn't a proper autotools package and I doubt it is now. To compile such software, you need to go into the makefile and know what you're doing (how to use makefiles and how to use gcc).
limpens
Sat Nov 30, 2013 7:54 am
You might take a look at bsquask.com
Once setup you'll have a nice buildroot based cross compile environment.
Return to “Advanced users”
