RobHenry
Re: Super slow USB HDD after apt-get upgrade ?
Tue Oct 01, 2013 12:58 pm
This is fixed in yesterday's firmware commit.
rpi-update should be safe for you now.
See https://github.com/raspberrypi/linux/issues/383
itsmedoofer
Contact: AOL
Tue Oct 01, 2013 7:52 pm
Nice one, thanks for the heads up !
jpd
Wed Oct 02, 2013 6:50 pm
RobHenry wrote:This is fixed in yesterday's firmware commit.
I just wanted to give some positive feedback about the update:
I have tried it today on a 512MB Model B and for my use case it seems to solve the USB stability problems of the former firmware releases. Using my external harddisk works again with the current firmware (dated Oct 1 2013 00:40:37) and the current git kernel (3.11.y branch, c9f21f0).
Regards,
jpd
violagirl23
Fri Oct 11, 2013 9:36 pm
I wanted to update as well. I've rebooted several times since I used the new firmware with no problems whatsoever. I just read that it's been fixed now, so I'll do a rpi-update and hopefully all will still be well! I really appreciate all the assistance.
DesolataX
Tue Feb 18, 2014 6:05 am
Bumping this slightly old thread because I'm having this same issue. Running Raspian, one USB webcam attached. If I run with dwc_otg.speed=1, I don't seem to get these issues, but limiting the cam to 12mbps results in poor streaming.
Any help would be appreciated.
root@raspberrypi:~# vcgencmd version
Feb 17 2014 21:35:01
Copyright (c) 2012 Broadcom
version f5c67bfc77e918b2c89a130bd2682dcab5903490 (clean) (release)
root@raspberrypi:~# uname -a
Linux raspberrypi 3.10.30+ #640 PREEMPT Fri Feb 14 19:09:14 GMT 2014 armv6l GNU/Linux
Feb 17 15:19:14 raspberrypi kernel: [ 141.879116] ERROR::handle_hc_chhltd_intr_dma:2591: handle_hc_chhltd_intr_dma: Channel 0, DMA Mode -- ChHltd set, but reason for halting is unknown, hcint 0x00000012, intsts 0x04000001
Feb 17 15:23:06 raspberrypi kernel: [ 373.723899] ERROR::handle_hc_chhltd_intr_dma:2591: handle_hc_chhltd_intr_dma: Channel 3, DMA Mode -- ChHltd set, but reason for halting is unknown, hcint 0x00000012, intsts 0x04000001
Feb 17 15:23:06 raspberrypi kernel: [ 373.723994] ERROR::handle_hc_chhltd_intr_dma:2591: handle_hc_chhltd_intr_dma: Channel 1, DMA Mode -- ChHltd set, but reason for halting is unknown, hcint 0x00000012, intsts 0x04000001
Feb 17 15:23:32 raspberrypi kernel: [ 399.697254] ERROR::handle_hc_chhltd_intr_dma:2591: handle_hc_chhltd_intr_dma: Channel 2, DMA Mode -- ChHltd set, but reason for halting is unknown, hcint 0x00000012, intsts 0x04000021
Feb 17 15:26:45 raspberrypi kernel: [ 593.192259] ERROR::handle_hc_chhltd_intr_dma:2591: handle_hc_chhltd_intr_dma: Channel 5, DMA Mode -- ChHltd set, but reason for halting is unknown, hcint 0x00000012, intsts 0x04000001
Feb 17 15:26:45 raspberrypi kernel: [ 593.192340] ERROR::handle_hc_chhltd_intr_dma:2591: handle_hc_chhltd_intr_dma: Channel 6, DMA Mode -- ChHltd set, but reason for halting is unknown, hcint 0x00000012, intsts 0x04000001
Feb 17 15:27:51 raspberrypi kernel: [ 659.329748] ERROR::handle_hc_chhltd_intr_dma:2591: handle_hc_chhltd_intr_dma: Channel 1, DMA Mode -- ChHltd set, but reason for halting is unknown, hcint 0x00000012, intsts 0x04000001
Feb 17 15:27:51 raspberrypi kernel: [ 659.329834] ERROR::handle_hc_chhltd_intr_dma:2591: handle_hc_chhltd_intr_dma: Channel 5, DMA Mode -- ChHltd set, but reason for halting is unknown, hcint 0x00000012, intsts 0x04000001
Return to “Advanced users”
