gstreeter
Re: Next firmware tree is now 3.10
Tue Nov 12, 2013 9:27 pm
I downgraded back to the 10 Nov build (8fd111f77895450323abc5b34efde19548ffc480) and the FSTRIM command functions ok. Upon re-upgrading to the latest rpi-update FSTRIM again fails with the ioctl error.
dom
Tue Nov 12, 2013 9:35 pm
gstreeter wrote:I downgraded back to the 10 Nov build (8fd111f77895450323abc5b34efde19548ffc480) and the FSTRIM command functions ok. Upon re-upgrading to the latest rpi-update FSTRIM again fails with the ioctl error.
Can you confirm if it is the gpu firmware or kernel?
i.e. does a latest rpi-update, with start*.elf and fixup*.dat reverted to 10 Nov version work?
gstreeter
Tue Nov 12, 2013 9:47 pm
Looks like it's the firmware. I ran rpi-update with SKIP_KERNEL=1 on the 10 Nov build. The #587 kernel was retained and the firmware updated. I now get the FSTRIM ioctl failure again with the updated firmware.
dom
Tue Nov 12, 2013 10:01 pm
gstreeter wrote:Looks like it's the firmware. I ran rpi-update with SKIP_KERNEL=1 on the 10 Nov build. The #587 kernel was retained and the firmware updated. I now get the FSTRIM ioctl failure again with the updated firmware.
It's hard to image what is causing it, but we can narrow it down some more. Go back to latest firmware, and added config.txt option:
emmc_pll_core=0
That should behave pretty much like the previous firmware.
gstreeter
Tue Nov 12, 2013 10:03 pm
A full rpi-update followed by restoring the 10 Nov firmware gives a functioning FSTRIM with the newer #590 kernel.
gstreeter
Tue Nov 12, 2013 10:16 pm
Latest rpi-update with emmc_pll_core=0 allows FSTRIM to work.
dom
Tue Nov 12, 2013 10:20 pm
gstreeter wrote:Latest rpi-update with emmc_pll_core=0 allows FSTRIM to work.
How about:
emmc_pll_core=1
init_emmc_clock=100000000
gstreeter
Tue Nov 12, 2013 10:26 pm
emmc_pll_core=1
Results in a working FSTRIM
dom
Tue Nov 12, 2013 10:41 pm
gstreeter wrote:emmc_pll_core=1
Okay, seems to be the higher emmc clock. I imagine if you do:
emmc_pll_core=0
init_emmc_clock=250000000
on either new or old firmware you will get the same effect (fstrim stops working).
I'm guessing it's reading some of teh sdcard config registers wrong. E.g.
 cat /sys/devices/platform/mmc_host/mmc0/mmc0*/*
may be different in the two cases.
gstreeter
Tue Nov 12, 2013 10:47 pm
I've just noticed a reply from ghollingworth on GitHub to the issue I raised about this:
"FSTRIM is not supported by SD cards therefore it failing is a good thing...
Previous updates were clearly incorrect and someone has fixed it more like"
dom
Tue Nov 12, 2013 10:54 pm
gstreeter wrote:I've just noticed a reply from ghollingworth on GitHub to the issue I raised about this:
Yes. Whether fstrim does anything useful on an sdcard is a different question.
There are a few thread on this forum about it, and results are inclusive.
Also it appears the ability to run fstrim comes and goes. See:
http://www.raspberrypi.org/phpBB3/viewt ... 63&t=19554
But that's not what I'm interested in. The fstrim behaviour changed for a surprising reason.
Being surprised normally means something funny is going on, and I'd like to understand what is happening.
gstreeter
Tue Nov 12, 2013 11:05 pm
I check the cat on the mmc device for the cases when FSTRIM works and fails. The results are identical.
g7ruh
Fri Nov 15, 2013 4:41 pm
Dom,
SPI is working in 3.10 now, thanks to you and popcornmix for your help and to chrisy for the issue on github
Roger
dom
Fri Nov 15, 2013 5:44 pm
g7ruh wrote: SPI is working in 3.10 now, thanks to you and popcornmix for your help and to chrisy for the issue on github
Glad it's working (and popcornmix is glad too :-))
Fri Nov 15, 2013 9:21 pm
Thank you.
I've had lots of fun this week trying each of your new firmware/kernel/module builds.
/dev/spidev0.0 and /dev/spidev0.1 have magically re-appeared with 3.10.18+ #596.
Nige C
Sun Nov 17, 2013 2:49 am
Thank you, my PiFace is working again. Thanks Dom and Popcornmix and others. SPI working now under 3.10. Great work thanks again.
Retired power engineer with a lot of real life experience. Life is an adventure again :)
mcgyver83
Mon Nov 18, 2013 7:40 am
B.Jay wrote:Okay... seems there's still a problem with SD card corruption and Overclocking going on (latest update installed) ...
config.txt snippet:
force_turbo=1
init_emmc_clock=500000000
emmc_pll_core=1
core_freq=500
arm_freq_min=700
arm_freq=1000
sdram_freq_min=400
sdram_freq=500
over_voltage=6
With these settings now my rasp passed a full stress test of 2 hours 100% cpu.
So from my point of view the sd corruption gone away :D :D :D
dom
Mon Nov 18, 2013 12:01 pm
mcgyver83 wrote: With these settings now my rasp passed a full stress test of 2 hours 100% cpu.
Good to hear it has worked.
With latest firmware, you don't have to specify emmc_pll_core=1 or init_emmc_clock (they will be set as a default).
force_turbo is optional - should be no problems with or without it.
fabriced
Mon Nov 18, 2013 12:59 pm
Master branch is on 3.10.19 and the next branch is on 3.10.18.
Now they are both on 3.10.y, it is unclear for me what is on each branch and we do not have the sources.
When I read the commits, I do not really understand what is or isn't in each.
Could it be possible to give a summary of the differences?
Or at least a summary for USB and SD fixes since these are the most tricky part of the Pi ?
Best regards,
Fabrice
B.Jay
Mon Nov 18, 2013 1:01 pm
config.txt snippet:
force_turbo=1
emmc_pll_core=1
core_freq=500
arm_freq_min=700
arm_freq=1000
sdram_freq_min=400
sdram_freq=500
over_voltage=6
Well, just for the LULZ I took a 256MB MMC (yes, a MMC card - good enough to "Kickstart" the Pi from it and make it continue booting from USB) I found in some old phone while clearing out my severely overflowing electronics junk carton box and put the firmware/kernel onto the card. To my surprise the Pi boots off of it without any problem and when mounting/un-mounting/mounting the vfat partition in the fully booted system I don't see the "was not cleanly unmounted" message popping up in the syslogs anymore (though it still happens with the Sony 2GB mSD-in-SD Adapter card where even Windows keeps on insisting that 'No errors found' upon a full chkdsk run - and yes, I peeked at the card with a HexEditor and the dirty-bit is fine).
Anyway, the MMC works perfect with the overclocked Pi, though I'm still resorting to my "rpi-update wrapper" that only mounts the card to copy files in case the firmware has been updated.
dom wrote:With latest firmware, you don't have to specify emmc_pll_core=1 or init_emmc_clock (they will be set as a default).
Thanks for the heads-up.
*goes editing his config.txt*
plugwash
Tue Dec 10, 2013 12:18 am
Are there still outstanding issues with 3.10 and/or the latest firmware that are preventing it being pushed to the foundation's apt repo?
gkreidl
Tue Dec 10, 2013 11:48 am
plugwash wrote:Are there still outstanding issues with 3.10 and/or the latest firmware that are preventing it being pushed to the foundation's apt repo?
yes, look here:
http://www.raspberrypi.org/phpBB3/viewt ... 58#p466644
Minimal Kiosk Browser (kweb)
dom
Tue Dec 10, 2013 12:27 pm
I'm not aware of any blocker issues. We're going through a beta test cycle of a new 3.10 based raspbian image that will end up with a new sdcard image and updated apt-repo.
Tue Dec 10, 2013 12:33 pm
I think the point is that we can't download the kernel headers or Linux source package for 3.10.##+ using apt-get.
dom
Tue Dec 10, 2013 2:11 pm
DougieLawson wrote:I think the point is that we can't download the kernel headers or Linux source package for 3.10.##+ using apt-get.
I don't believe this is the issue being discussed. This is no different from 3.6. See:
http://www.raspberrypi.org/phpBB3/viewt ... 66&t=57401
Return to “Advanced users”
