wireless WLAN bridge
Posted: Wed Jun 05, 2013 1:57 pm
by Deliberatus
I read and enjoyed the article on creating a hot spot- and did so with a pi, it works fine; th8is could be a very useful tool. Now, what about a wireless network range extending bridge using 2 wifi dongles and appropriate configurati9on? Let's kick this around some!
:D
Re: wireless WLAN bridge
Posted: Thu Jun 13, 2013 4:33 pm
by SirLagz
Depending on the WiFi sticks, this could be difficult.
I'm trying to do it now by bridging and finding it hard to do.
itd be easier making it into a WiFi router.
Posted: Fri Jun 21, 2013 4:57 am
by YodaDaCoda
I've actually almost completely managed to do this. The only problem I'm having is routing DHCP and DNS requests to the router using iptables. Maybe there's something I'm missing, but if someone know things about iptables (I'm hardly a linux noob, but iptables confuses the hell out of me) I'd appreciate some help. Naturally, I'd do a proper write-up afterwards.
Posted: Fri Jun 21, 2013 5:45 am
by SirLagz
YodaDaCoda wrote:I've actually almost completely managed to do this. The only problem I'm having is routing DHCP and DNS requests to the router using iptables. Maybe there's something I'm missing, but if someone know things about iptables (I'm hardly a linux noob, but iptables confuses the hell out of me) I'd appreciate some help. Naturally, I'd do a proper write-up afterwards.
Are you using bridging or routing ?
if you're bridging, iptables *shouldnt* come into it.
If you're routing, then it's not really bridging, and you just setup iptables like a router.
Posted: Fri Jun 21, 2013 8:09 am
by MattF
I looked into how to do this, and there are some challenges in bridging over Wireless because of the differences at layer 2.
If you can get full 4 addr support setup, then you are in with half a chance, but even then there are likely to be problems.
Happily there is a solution that "just works".
Build a normal Master/Managed Wi-Fi relationship between the two nodes.
Bridge the Wi-Fi adapters to the wired ethernet.
Then build an openvpn across the Wi-Fi segment in bridged mode.
This results in a full transparent layer 2 bridge in place, with no worries about mac addresses, NAT or any other such complication.
http://christian.hofstaedtler.name/blog ... envpn.html was very useful in getting OpenVPN correct - just remember it's a Wi-Fi segment rather than the Internet in between your pair of devices.
Rgds,
Matt
Posted: Fri Jun 21, 2013 11:43 am
by SirLagz
MattF wrote:Hi,
Rgds,
Matt
That link looks very interesting, Thanks for that Matt
I've been trying to implement layer 2 bridging over wifi for a long time now with the Pi
Posted: Fri Jun 21, 2013 11:53 am
by YodaDaCoda
SirLagz wrote:Are you using bridging or routing ?
I'm not bridging the connections; I'm routing using iptables. I still have to figure out why iptables isn't routing the dhcp requests, and I suspect it may be something to do with the way I did the nat translation chain stuff (copied a few lines from stackexchange) - I think it's dropping udp packets. But that's a job for Monday.
Posted: Fri Jun 21, 2013 12:01 pm
by SirLagz
Ahh. If you're routing, then you'll need to install a dhcp server on your Pi, and that will hand out IP addresses.
NAT won't work on the layer 2 level.
When a computer transmits a DHCP broadcast packet, it won't go over the WiFi as when it goes out over the WiFi, the source MAC address would change and the router would assign an IP address to the wrong MAC address.
I normally use dnsmasq as my DHCP server.
