I found somewhat of an answer in the faqs (should have looked there first
) However, the faq didn't necessarily have a solid answer. I'll post it here in case anyone else has the same question and didn't look at the faq first: "The Raspberry Pi is built from commercial chips which are qualified to different temperature ranges; the LAN9512 is specified by the manufacturers being qualified from 0°C to 70°C, while the AP is qualified from -40°C to 85°C. You may well find that the board will work outside those temperatures, but we’re not qualifying the board itself to these extremes."
