Page 4 of 4
Re: CONFIG_PREEMPT_RT on Raspberry Pi
Posted: Sun Jun 08, 2014 1:45 pm
by twobob
Aye all good advice.
However having spent many days in the past faffing around with the "wrong" files on other projects it would be nice to know that I am at least starting with the right ones :)
Thanks for the feedback, I read the entire thread again just in case I missed something.
Posted: Wed Jan 21, 2015 3:17 pm
by clouded
Hello realtimers,
I build kernels with PREEMPT_RT from time to time and just built the fresh one a couple of days ago - 3.12.36-rt50+.
Links to sources, kernel and SD image are provided below.
Cyclictest results: #Min: 00011uS #Avg: 00023uS #Max: 00066uS
Raspberry Pi linux kernel source patched with rt-patch and config for PREEMPT_RT:
https://github.com/emlid/linux-rt-rpi
Standalone Raspberry Pi linux kernel with modules version 3.12.36-rt50+:
https://mega.co.nz/#!YNRV3RzL!Zvj6-2E8P ... YxYPM5vC5Q
SD card image based on 2014-12-24 Raspbian with 3.12.36-rt50+ kernel and few modifications:
https://mega.co.nz/#!UMZRkJ6Z!4uJF3UTsa ... wIW7Q9WlSc
More information about the image can be found at http://www.emlid.com/new-raspbian-with- ... -jan-2015/.
Posted: Fri Feb 27, 2015 3:05 pm
by clouded
Hi everyone,
I tried the new 3.18 rt kernels for Raspberry Pi A+\B+ as well as new Raspberry Pi 2.
Kernel for Raspberry Pi A+\B+ seems to work okay.
Kernel for Raspberry Pi 2 has a problem - it freezes without any message (even with debug information enabled) when some process is run on cpu0 with priority <= -51, which is probably caused by the FIQ USB driver. Non-FIQ USB driver does not boot with an error.
If anyone wants to play with rt kernels for old and new RPis here's the patched source code with configs for rt - https://github.com/Clouded/linux-rt-rpi2
Posted: Mon Mar 30, 2015 10:58 am
by clouded
I was able to solve the issue that prevented booting with the non-FIQ USB driver. It required the following fix:
https://github.com/Clouded/linux-rt-rpi ... 71a99b283a
Now it is possible to boot with the non-FIQ USB driver by adding these options to the /boot/cmdline.txt :
dwc_otg.fiq_enable=0 dwc_otg.fiq_fsm_enable=0 dwc_otg.nak_holdoff=0
Compiled PREEMPT_RT kernel 3.18 for Raspberry Pi 2 can be downloaded here:
https://mega.co.nz/#!NBhBCSDJ!KSQm9OKU9 ... yexdcg6N1I
Patched source code is available here:
Posted: Tue Mar 31, 2015 11:26 am
by mung
clouded wrote:I was able to solve the issue that prevented booting with the non-FIQ USB driver. It required the following fix:
Interesting, have you got details of your kernel config?
I compiled for rpi2 with full RT_PREEMPT about a month ago the patch applied totally clean and the kernel booted without problem or error. The cyclictest results (max about 150 min 15us, though my memory is probably a bit poor so could be different) were only marginally better than for a rpi1, but the system never showed any error.
Also what are the cyclictest results with your patched kernel?
Posted: Mon Feb 15, 2016 12:12 am
by PabloGN
Hi people.
I didn't found your work before starting the work I describe in http://www.ehu.eus/ehusfera/pablogn/201 ... berry-sbc/
It is a very easy way of kernel building (thanks to Hypriot guys), and it behaves well until stressed with cyclictest and commands like
ssh user@desktop cat /dev/zero | dd of=/dev/null
Would you tell me the way to configure? It's maybe the soft irqs, maybe the parameters for cyclictest.
Posted: Mon Mar 07, 2016 3:10 pm
by kinsa
I have patched 4.4 kernels for RPi1/2 available here.
To install for RPi2:
apt-key adv --keyserver hkp://keys.gnupg.net --recv-key 43DDF224
echo "deb http://deb.machinekit.io/debian raspbian main" > /etc/apt/sources.list.d/machinekit.list
apt-get update
apt-get install -y linux-image-rpi2-rt
cd /boot
echo kernel=$(ls kernel_rt*.img) >> config.txt
echo device_tree=dtbs_rt/bcm2709-rpi-2-b.dtb >> config.txt
For RPi v1, use
apt-get install -y linux-image-rpi-rt
and adjust device_tree accordingly.
Don't forget to append the following entries to /boot/cmdline.txt:
Sources are located here.
Cheers
Update:
- fixed device_tree entry
Posted: Sat Mar 12, 2016 11:31 am
by kinsa
BTW, linux 4.4 needs an updated bootloader, do:
sudo apt-get update
sudo apt-get install -y raspberrypi-bootloader
Posted: Sat May 07, 2016 5:30 pm
by DaveO16
I've followed these steps with a B+ "Raspberry Pi Model B+ V1.2", ammending dtoverlay in config.txt to
dtoverlay=dtbs_rt/bcm2708-rpi-b-plus.dtb
When I reboot I get a rainbow screen.
if I comment out the "new" kernel in config.txt all is OK.
The image I've installed this on is the most recent.
How do I debug this?
Posted: Sat May 07, 2016 11:48 pm
by kinsa
Can you post your config.txt?
Posted: Sun May 08, 2016 1:04 am
by cjan
supported 4.4, does it mean 4.4.1~x ?
Posted: Mon May 09, 2016 12:58 pm
by DaveO16
kinsa wrote:Can you post your config.txt?
Yup, absolutely... thank you for being willing to help...
$ cat /cygdrive/e/config.txt
# For more options and information see
# http://www.raspberrypi.org/documentation/configuration/config-txt.md
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
#disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
#hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
hdmi_group=2
hdmi_mode=17
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
arm_freq=900
# Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# Uncomment this to enable the lirc-rpi module
#dtoverlay=lirc-rpi
# Additional overlays and parameters are documented /boot/overlays/README
dtparam=audio=on
core_freq=250
sdram_freq=450
over_voltage=2
kernel=kernel_rt-4.4.4-rt9+.img
Posted: Mon May 09, 2016 2:04 pm
by PhilE
This looks wrong:
The file is named like a base DTB file (a complete description of the common hardware for a board) but you are loading it like an overlay (a patch to modify a base DTB).
Try this:
device_tree=dtbs_rt/bcm2708-rpi-b-plus.dtb
Posted: Thu May 12, 2016 10:14 am
by DaveO16
That worked... time to learn about PREEMPT_RT!
Thank you!
