1. - Hardware Requirements - 1x per each PI:
for | what | why | Vendor
USB Path | Powered USB HUB | Multible USB dev | i.e Belkim
IPVS Cluster sync | GPIO RS232 Serial adaper | avoid split brains | https://www.adafruit.com/products/954
Linux Console | usb serial Adapter | Serial Console | multible , look for an linux supported one
2. USB Ethernet 100MB | usb ethernet adapter | Heartbeat sync | multible , look for an linux supported one
The 2. usb ethernet may optional . read the http://www.linuxvirtualserver.org/software/ipvs.html pages.
Myself hate not stable clusters ;-) .
You need an Serial NULLmodem kabel - Google "serial null modem cable" , or look for an local vendor nearby.
2. - Software Requirements :
Debian 6 for PI seems NOT deliver the IPVS Modules .
Fedora Remix 17/18 seems to deliver the IPVS Modules .
As kernel recompile take 6-9h , and i wanted no manual kernel updates.
I chosed FC remix 18 rasp !!
3. IPVS Planing
IPVS Beginners : RTFM - read the Fucking manuals :-)
-> http://www.linuxvirtualserver.org/docs/ha/heartbeat_ldirectord.html
-> http://www.linuxvirtualserver.org/software/ipvs.html
-> http://www.linux-ha.org/wiki/Pacemaker
-> http://www.linux-ha.org/wiki/Heartbeat
.. some more wikis exist On Internet for detailed HowTows.
4. IPVS with PI - Hardware setup
A -> setup 2 Pi with FC 18 rasp ,
Both the same config ,
Same Netmask ,
same serials
same software
B -> change serial console to /dev/USB01
for this you need to update the boot config , change console= to an USB tty.
see this page : http://www.irrational.net/2012/04/19/using-the-raspberry-pis-serial-port/
C -> install an GPIO RS 232 adapter
i.e https://www.adafruit.com/products/954
i.e http://wolfpaulus.com/journal/embedded/raspberry_serial
D -> Plug an Serial Nullmodem Cabel between the both GPIO RS 232 adapter
see : http://en.wikipedia.org/wiki/Null_modem
see : http://www.linux-archive.org/centos/188608-cluster-heart-beat-using-cross-over-cable.html
Test with minicom : https://nmi.cs.wisc.edu/node/878
If the Test hast been succeed in both directions ,
then you ready to use it for the "ANTI SPLIT BRAIN " crossover heartbeat cable.
..RTFM..
5 -> install required IPVS RPMs( FC 18-2 ):
[root@lb1 ha.d]# rpm -qa | egrep -e '(ipvsadm|pacemaker|drbd-|httpd-|mon.armv5tel|bind-)' | egrep -v '(libmicro|rpcbind)'
bind-dyndb-ldap-2.3-2.fc18.armv5tel
drbd-pacemaker-8.3.13-1.fc18.armv5tel
bind-lite-devel-9.9.2-6.P1.fc18.armv5tel
drbd-8.3.13-1.fc18.armv5tel
pacemaker-cli-1.1.8-3.fc18.armv5tel
ipvsadm-1.26-6.fc18.armv5tel
bind-sdb-9.9.2-6.P1.fc18.armv5tel
bind-to-tinydns-0.4.3-9.fc18.armv5tel
drbd-heartbeat-8.3.13-1.fc18.armv5tel
pacemaker-doc-1.1.8-3.fc18.armv5tel
pacemaker-libs-devel-1.1.8-3.fc18.armv5tel
pacemaker-cluster-libs-1.1.8-3.fc18.armv5tel
bind-libs-9.9.2-6.P1.fc18.armv5tel
bind-chroot-9.9.2-6.P1.fc18.armv5tel
bind-pkcs11-9.9.2-6.P1.fc18.armv5tel
drbd-utils-8.3.13-1.fc18.armv5tel
drbd-bash-completion-8.3.13-1.fc18.armv5tel
pacemaker-libs-1.1.8-3.fc18.armv5tel
pacemaker-1.1.8-3.fc18.armv5tel
bind-license-9.9.2-6.P1.fc18.noarch
bind-9.9.2-6.P1.fc18.armv5tel
bind-devel-9.9.2-6.P1.fc18.armv5tel
drbd-udev-8.3.13-1.fc18.armv5tel
bind-libs-lite-9.9.2-6.P1.fc18.armv5tel
bind-utils-9.9.2-6.P1.fc18.armv5tel
pacemaker-cts-1.1.8-3.fc18.armv5tel
6. HA Setup
Bring IP apache, bind on each LB.
Setup Minimalistc test pages as Wikis suggest
Setup NTP Both LB require to have the same date & Time !!
Setup i.e Bind as local cache, this speedup lookups for ldirectord.
Bring UP heartbeat , configure it
Bring UP ldirectord , configure it
TEST the cluster , poweroff one LB node, the second must take over !
If you want , Bring UP pacemaker , configure it ..
Myself not Run X11 on the LB..
Asume you have allready REAL servers setup , so start using them
Follow i.e http://www.linuxjournal.com/article/9838 /
ALL well done ?, have FUN ;-)
Cheers.
