toadbrother
Locked Down Profile
Tue May 18, 2021 9:41 pm
I'm looking at replacing our aging Windows machines with Raspberry Pis. The Windows machines all run Deep Freeze, which essentially resets the Windows profile with every reboot. I'm looking at similar functionality on the Pis. I have a good deal of experience with Unix/Linux, so the most obvious solution to me is to simply recreate the public user home directory from a master home directory on every reboot, via CRON. Any changes that need to be made to the master user home directory can be done by logging into as that user. Does this seem reasonable?
As a corollary to that, I'm thinking of having the master home directory sitting on a Samba or NFS share, which allows the update to be done to one single profile rather than 20 or 30 Pis. At boot up, each Pi will reset the public user home directory with the one sitting on the server.
Is this an overly complicated way to do things? Is there a better way to lock down a user home directory and reset the settings?
pidd
Re: Locked Down Profile
Tue May 18, 2021 10:42 pm
The simplest but possibly less hacker-proof way is to use the overlay file system in raspi-config, effectively it is run from in RAM disks and all changes get lost when re-booted.
ejolson
Tue May 18, 2021 11:18 pm
The way it's usually done for a student lab with Pi computers is even easier than Deep Freeze, because Raspberry Pi OS can boot diskless (no SD card either) over the network. Thus, centralised adminstration is automatic and involves only the boot and file server.
While this may sound complicated, there is an officially supported solution called PiServer which makes it all plug-and-play in most cases. Hopefully someone can chime in with how to get started.
Wed May 19, 2021 3:45 am
https://www.raspberrypi.org/blog/piserver/
https://github.com/raspberrypi/piserver
I am a volunteer, take what I advise as advice not the utopian holy grail.
Return to “Advanced users”
