Question about Enlightenment
I'm going to install the Enlightenment (E17) desktop environment. I have a question about source. Do packages.enlightenment org packages will work with the Raspberry Pi, is it necessary to use the packages prepared by Bodhi. The second thing which interests me is that the GPU can handle with ecomorph.
Re: Question about Enlightenment
It is usually easier to use packages that are available in the repository for your distribution, but being linux, it generally is possible, although not necessarily easy, to tweak packages used for other distributions or recompile from upstream sources for your particular installation.
If you are running Bodhi, you might ask in a Bodhi forum if nobody else comes along here who knows your distribution.
FORUM TIP: To view someone's posting history, sign in, click on their user name, then on "Search User's Posts." || Running ArchLinuxArm on Model 2B and 512MB Model B
There is no problem running Bodhi Linux (Enlightenment desktop) on the Pi. I assume you have downloaded the Bodhi Linux image for the Pi from http://bodhilinux.com/downloads_mobile.php, and that you have updated it with sudo apt-get update && sudo apt-get dist-upgrade.
The Bodhi repository for ARM devices (including the Raspberry Pi) is included in your sources.list and will appear along with Debian/Raspbian repository when you run Synaptic. Alternatively you can directly download Bodhi-recommended packages for ARM devices from http://appcenter.bodhilinux.com/software/arch/armel (note that you will have to use the Midori web browser to do a direct download from appcenter).
Note that Bodhi Linux for the Pi runs on Raspbian (Debian Wheezy) NOT Ubuntu, and all packages for standard Raspbian will work on it (indeed, some of them run better under Bodhi than under LXDE).
You can also if you wish update to the latest kernel (Linux 3.6.11) and firmware using rpi-update.
One thing to avoid though: don't attempt to expand the file system to fill the SD card using the option in raspi-config - it will probably corrupt your Bodhi image. Use Gparted instead.
If you have further questions about running Enlightenment on the Pi, you can post them on the Raspberry Pi section of the Bodhi Linux forum here: http://forums.bodhilinux.com/index.php? ... pberry-pi/
Enlightenment is a Desktop Environment on top of a Linux Distribution (Operating System).zalewskig wrote:I'm going to install the Enlightenment (E17) desktop environment. I have a question about source. Do packages.enlightenment org packages will work with the Raspberry Pi, is it necessary to use the packages prepared by Bodhi. The second thing which interests me is that the GPU can handle with ecomorph.
You ask if packages can work with the Raspberry Pi and the answer is no as the Pi is a computer !
Bodhi is the best choice for 'out-of-the-box' as stated above..
Arch Linux Arm (alarmpi) has the packages in their ARMv6 repository for Enlightenment Desktop, though Arch is a Command Line Distro by default. If you are concerned about resource usage then Arch is good
Arch does not have the range of packages which are available to Debian based Distro's and is more of a learning curve.
I know everything about nothing"
jheaton5@raspberrypi ~ $ aptitude search e17
p e17 - Enlightenment DR17 Window Manager
p e17-data - Enlightenment Window Manager Run Time Data
p e17-dbg - Enlightenment DR17 Window Manager - debugg
p e17-dev - Enlightenment headers, static libraries an
v libghc-bytestring-dev-0.9.2.1-e -
v libghc-bytestring-prof-0.9.2.1- -
I know that the Raspberry pi is not the computer, debian and I know him for more than a decade faithful. Uninstall unnecessary packet was not a challenge. But at the moment, are located to the config.txt unknown command (which I used), which, moreover, do not work as they should (color bias, because as yellow can be blue). So please answer that can solve the problem, and will not verify my understanding of the system operated.
My post merely pointed out that E-17 was already in the Raspbian repository so why did you need to seek a source outside? If I misunderstood your initial question, I apologize.jheaton5 wrote:Code: Select all
jheaton5@raspberrypi ~ $ aptitude search e17 p e17 - Enlightenment DR17 Window Manager p e17-data - Enlightenment Window Manager Run Time Data p e17-dbg - Enlightenment DR17 Window Manager - debugg p e17-dev - Enlightenment headers, static libraries an
