Raspberry Pi EEPROM Manager
Raspberry Pi EEPROM Manager (rpi-eeprom-mgr) is a menu-driven front-end for rpi-eeprom-update.
Available actions are:
Display EEPROM Status
Update Bootloader EEPROM
Edit Bootloader Configuration
Update VL805 (USB) EEPROM
Remove Pending Update
Change Firmware Directory
Disable Automatic EEPROM Updates
Enable Automatic EEPROM Updates
Automatic EEPROM Update Status
All actions have a confirmation prompt before being executed.
- Attachments
- rpi-eeprom-mgr.zip
- (3.15 KiB) Downloaded 736 times
Re: Raspberry Pi EEPROM Manager
Great , is in the official repository?RonR wrote: ↑Fri Aug 21, 2020 12:06 amRaspberry Pi EEPROM Manager (rpi-eeprom-mgr) is a menu-driven front-end for rpi-eeprom-update.
Disable EEPROM Update Service
Enable EEPROM Update Service
Nice job.
rpi-eeprom-mgr (in the first post of this topic) has been updated.
The previous version contained two actions that allowed automatic EEPROM updates to be disabled/enabled:
These actions have been replaced by:
These new actions allow automatic EEPROM updates to be disabled/enabled without exacerbating the Serious Problem in Bootloader EEPROM.
rpi-eeprom-mgr has been enhanced to circumvent the issue described in the topic: Serious Problem in Bootloader EEPROM
rpi-eeprom-mgr now ensures that no previous EEPROM updates are pending, thus preventing the possibility of an endless EEPROM reprogramming loop.
Why not share this via a Github (or similar) repository rather than a download that some might be suspicious of? I certainly won't download a random zip
To be fair it's a bash script which can easily be examined before execution.
E8 85 A2 40 C9 40 81 94 40 81 95 40 89 84 89 96 A3
Still NF Shirls
Still NF Shirls
Typo on line 368 "errrxit"
It's attached to the first post of this topic (rpi-eeprom-mgr.zip).
Simply extract rpi-eeprom-mgr (unzip rpi-eeprom-mgr.zip), make it executable (chmod +x rpi-eeprom-mgr) and run it (sudo ./rpi-eeprom-mgr).
[/quote]
Where do i put "rpi-eeprom-mgr"? I extracted it on my desktop but when i go into command line and type in "chmod +x rpi-eeprom-mgr". I get an error that says " chmod: cannot access 'rpi-eeprom-mgr': No such file or directory "
I am stuck on what to do from here. Please help
[/quote]
skr1b wrote: ↑Wed Sep 23, 2020 3:51 amWhere do i put "rpi-eeprom-mgr"? I extracted it on my desktop but when i go into command line and type in "chmod +x rpi-eeprom-mgr". I get an error that says " chmod: cannot access 'rpi-eeprom-mgr': No such file or directory "
You can put rpi-eeprom-mgr anywhere you like.
If it resides on your desktop and you open a command prompt in /home/pi, you would execute:
chmod +x Desktop/rpi-eeprom-mgr
sudo Desktop/rpi-eeprom-mgr
or
cd Desktop
or
[/quote]
Thanks but no luck still getting same error message for both . Am I doing something wrong? File is still on my desktop
chmod: cannot access 'Desktop/rpi-eeprom-mgr': No such file or directory
or
cd Desktop
chmod + x rpi-eeprom-mgr
I just tried both methods here and they both work as expected.
Is your command prompt running in /home/pi/Desktop when you run 'chmod +x rpi-eeprom-mgr'? Does 'ls -l' show rpi-eeprom-mgr?
[/quote]
I attached a screen shot of what I tried. How do i know if my command prompt is running in home/pi/desktop? Im using Putty![Image]()
[/quote]
- Attachments
- Screenshot
- Screenshot 2020-09-23 150427.png (32.52 KiB) Viewed 2877 times
Your command prompt shows your current location:
pi@retropie:~/Desktop $
The '~' means your HOME directory (/home/pi).
What does 'ls -l /home/pi/Desktop' show? You should see whatever is on your Desktop, including:
-rw-r--r-- 1 pi pi 13505 Sep 23 17:19 rpi-eeprom-mgr
Both of your attempts were incorrect.
In the first one, you typed rpi-eeprom=mgr instead of rpi-eeprom-mgr.
In the second one, you typed '+ x' instead of '+x'.
Something else to try is: 'find ~ -name rpi-eeprom-mgr'
It should display: '/home/pi/Desktop/rpi-eeprom-mgr'
[/quote]
I did the above and attached a screenshot. Its not showing up even though its on my desktop?
[/quote]
- Attachments
- Screenshot 2020-09-23 163316.png (22.24 KiB) Viewed 2835 times
RonR wrote: ↑Wed Sep 23, 2020 11:41 pm
One last shot...
sudo find / -name rpi-eeprom-mgr
nothing... so strange. What if i put the file somewhere in my pi folder with SSH? Like retropie/configs/all or somewhere it might be able to read it other then my desktop?
I don't know what you have on your desktop that appears to be rpi-eeprom-mgr, but Linux says there's no file by that name anywhere on your system.
It doesn't matter where you put rpi-eeprom-mgr as long as you can find it, make it executable with chmod, and run it.
You didn't exactly answer his question.
Raspberry Pi OS (32-bit) with desktop and recommended software
Raspberry Pi 4 Model B 8GB at stock speed (never overclock)
Never overclock your Pi.
Encourage optimization instead.
AkulaMD wrote: ↑Thu Sep 24, 2020 3:20 amYou didn't exactly answer his question.
It appears the answer is no:
root@raspberrypi:~# apt search rpi-eeprom-mgr
Sorting... Done
Full Text Search... Done
root@raspberrypi:~#
[/quote]
Well...i tried it. And it atleast now says its on my system... can you help me from here now with correct commands?
Sorting... Done
root@raspberrypi:~#
[/quote]
- Attachments
- Screenshot 2020-09-23 204727.png (4.24 KiB) Viewed 2745 times
sudo chmod +x /opt/retropie/configs/all/rpi-eeprom-mgr
sudo /opt/retropie/configs/all/rpi-eeprom-mgr
INCREDIBLE! It workedRonR wrote: ↑Thu Sep 24, 2020 3:56 amCode: Select all
sudo chmod +x /opt/retropie/configs/all/rpi-eeprom-mgr sudo /opt/retropie/configs/all/rpi-eeprom-mgr
